[QGIS-Developer] Authentication seems broken in master
Bernhard Ströbl
bernhard.stroebl at jena.de
Thu Nov 2 07:28:01 PDT 2017
Hi Andreas,
I was under the impression that the qgis-auth.db is supposed to reside
at $HOME/.local/share/QGIS/QGIS3/profiles/default because that is where
QGIS3 recently installed plugins (a while ago indeed it was
$HOME/.qgis3). I just copied my qgis-auth.db from $HOME/.qgis2 to
$HOME/.local/share/QGIS/QGIS3/profiles/default and get "Auth db query
exec() FAILED", too, upon opening options-cAuthentication
Bernhard
Am 02.11.2017 um 15:18 schrieb Andreas Neumann:
> Hi Alessandro,
> Already at the start of QGIS I get two times the error message:
> WARNING: Auth db query exec() FAILED
> This happens during startup of QGIS without any user interaction.
> I had a look at the permissions of $HOME/.qgis3/qgis-auth.db - and they
> seem fine to me.
> Perhaps, if I/we can fix this, the other subsequent error message go
> away as well?
> Thanks,
> Andreas
> On 2017-11-02 15:04, Alessandro Pasotti wrote:
>> On Thu, Nov 2, 2017 at 2:54 PM, Andreas Neumann <a.neumann at carto.net
>> <mailto:a.neumann at carto.net>> wrote:
>> Hi Alessandro,
>> Thank you for your reply.
>> I don't know what I need to do to fix the auth-db issues. I keep
>> getting tons of error messages like
>> Auth DB query exec failed()
>> for existing connections.
>> This is for access through the GUI, not through Python.
>> Also, when I try to create a new auth config entry, it doesn't
>> know my master password anymore and can't create a new one. Pretty
>> broken currently.
>> Does this mean that my auth-db is corrupt and that I need to
>> remove it and create a new one?
>> I've honestly no idea: it is not broken for me, I'm using the auth
>> manager right now on master with no issues and the authmanager tests
>> are all green (and there are quite a few).
>> I suggest you to file a bug report with some more details that can
>> help to reproduce the issue.
>> Thanks!
>> Thanks for your reply,
>> Andreas
>> On 2017-11-02 14:38, Alessandro Pasotti wrote:
>> On Thu, Nov 2, 2017 at 2:19 PM, Andreas Neumann
>> <a.neumann at carto.net <mailto:a.neumann at carto.net>> wrote:
>> Same for me. Very annoying.
>> Bernhard please file a ticket and assign it to Alessandro
>> or Luigi.
>> Thanks,
>> Andreas
>> Hi,
>> the API has changed and the singleton has been removed.
>> Auth manager instance is now accessible through the
>> QgsApplication as QgsApplication.authManager()
>> Please file a ticket for filling the API break document that
>> the lazy coder forgot to do (blame on him!).
>> btw, the lazy coder did not forget to fill the API break
>> document for the `get` removal, see
>> https://qgis.org/api/api_break.html#qgis_api_break_3_0_QgsAuthManager
>> <https://qgis.org/api/api_break.html#qgis_api_break_3_0_QgsAuthManager>
>> On 2017-11-02 14:05, Bernhard Ströbl wrote:
>> Hi all,
>> I cannot convince freshly compiled current master 1ffc3fd
>> to save an authentication database.
>> Furthermore the Python access to QgsAuthManager via
>> QgsAuthManager.instance() seems broken, too:
>> "type object 'QgsAuthManager' has no attribute 'instance'"
>> Both already worked in a former version (compiled about 2 weeks ago)
>> any hints?
>> shall I file tickets?
>> regards
>> Bernhard
>> __________ Information from ESET Mail Security, version of virus signature database 16343 (20171102) __________
>> The message was checked by ESET Mail Security.
>> http://www.eset.com
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> List info:
>> Unsubscribe:
>> Alessandro Pasotti
>> w3: www.itopen.it <http://www.itopen.it>
>> Alessandro Pasotti
__________ Information from ESET Mail Security, version of virus signature database 16344 (20171102) __________
http://www.eset.com
