[QGIS-Developer] loadLayerDefinition does not respect relative path from qlr file
René-Luc Dhont
rldhont at gmail.com
Tue Nov 7 00:56:44 PST 2017
Hi Devs,
I have found the issue: https://issues.qgis.org/issues/15656 that has
been closed because the issue has been fixed in master. I reopened it
because it has not been fixed in LTRs.
I have opened a Pull Request to fix it in 2.18
https://github.com/qgis/QGIS/pull/5553
Regards,
René-Luc
Le 06/11/2017 à 20:50, René-Luc Dhont a écrit :
> Hi Devs,
> I will propose a PR to fix it.
> Regards,
> René-Luc
> Le 06/11/2017 à 17:23, René-Luc Dhont a écrit :
>> Hi Devs,
>> I have found a bug in 2.18 that annoy me a lot:
>> * I can't load a layer definition in an existing project because the
>> relative path in the layer definition is interpreted from the project
>> file and not the layer definition file (.qlr)
>> So the layer definition can only be used in an not already saved
>> project.
>> Do you know, how to force the absolute path ?
>> Regards,
