[QGIS-Developer] Travis timeout
Patrick Valsecchi
patrick.valsecchi at camptocamp.com
Wed Nov 8 00:41:44 PST 2017
OK, one step further. But I must be missing something because the tests
in tests/src/python/test_qgsserver_wms.py are just failing. From the looks
of the diff, it must be a font that is different. See the image in
attachment.
Any idea how to fix that?
On Wed, Nov 8, 2017 at 9:26 AM, Alessandro Pasotti <apasotti at gmail.com>
wrote:
> Hi Patrick,
> to run python tests locally you can either use ctest from the build dir or
> create a wrapper script that set paths and env vars before launching python
> and the script.
> Here is mine (you probably need to adapt it): http://dpaste.com/1C3FMZM
> Recently Matthias also explained on this list how to run python tests
> inside QtCreator.
> Cheers
> On Wed, Nov 8, 2017 at 9:22 AM, Patrick Valsecchi <
> patrick.valsecchi at camptocamp.com> wrote:
>> Hi,
>> I'm trying to work on a feature in the master branch, but Travis constantly
>> times out on my builds
>> <https://travis-ci.org/pvalsecc/QGIS/jobs/297999069>.
>> Did I miss something?
>> Plus, I'm trying to run UTs on my machine, but the doc must be outdated.
>> How do I run the tests in tests/src/python/test_qgsserver_wms.py locally?
>> Thanks for your help
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3: www.itopen.it
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171108/ea555237/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171108/ea555237/attachment-0001.png>
