[QGIS-Developer] Import Python modules from another installed plugin, if present
Richard Duivenvoorde
rdmailings at duif.net
Wed Nov 8 10:16:04 PST 2017
On 08-11-17 18:49, Tom Chadwin wrote:
> Hello all
> In a Python plugin, I would like to import some modules from another QGIS
> plugin, if it is installed. Is that possible?
Hi Tim,
Yes, I use the qgis.utils.plugins module to check if TimeManager is
available:
from qgis.utils import plugins
plugins then is a dictionary with loaded plugins
You can for example check IF a plugin is loaded:
https://github.com/rduivenvoorde/jrodos/blob/master/jrodos.py#L1463
if so you can just import modules:
from timemanager.layer_settings import LayerSettings
from timemanager.timevectorlayer import TimeVectorLayer
from timemanager.raster.wmstlayer import WMSTRasterLayer
Regards,
