[QGIS-Developer] QgsServer and 3d tiles
G. Allegri
giohappy at gmail.com
Thu Nov 9 07:49:30 PST 2017
Hi Vincent,
I agree tiled static data can, and should, be served as static content but
what I meant was having something like Tilestache, GeoWebCache, MapCache,
etc.. They're meant to render and cache on the fly, or preseeding the
tileset.
My question raised from the fact that QGIS 3D renderer could be a common
base to produce terrain meshes (a la Cesium) and 3D tiles, both for the
desktop 3D viewer and for a cached tileset to be served through HTTP.
QgsServer could use the same code base to populate the cache, but this
doesn't prevent having a Processing tool (ore whatever) doing the work in
advance.
You're working with gltf. What about OGC I3S?
giovanni
Il 9 nov 2017 16:29, "Vincent Picavet (ml)" <vincent.ml at oslandia.com> ha
scritto:
Hello,
On 03/11/2017 21:04, G. Allegri wrote:
> What if we had a QgsServer service dedicates to serving 3d tiles for
> Cesium or iTowns?
> Is anybody working on this?
At Oslandia, we work on 3D topics a lot, and 3d tiles in particular. We
are implementing 3D Tiles support in iTowns, and several components to
serve this format as webservices.
E.g. :
- https://github.com/Oslandia/building-server
- https://github.com/Oslandia/lopocs
I do not think having QGIS Server serving 3D tiles is a really good idea.
First, 3D tiles is a format ( and protocol) to serve tiles of objects in
a mostly static way. Therefore, what would be interesting is for QGIS to
have a way to export data as 3d Tiles. These tiles can then be served
with a simple HTTP server, no need for a QGIS Server component.
Moreover, there are a lot of use cases where we want to serve 3D Tiles
without using QGIS at all. Component-oriented architecture is better
than monolithic software.
What I see as best approach would be to mutualize as much code as
possible regarding 3D tiles in py3dtiles :
https://github.com/Oslandia/py3dtiles
Using this module, we can write a 3dtile exporter, as a Processing
module for example. We already have some draft code to do that for some
data sets.
Then, we could have an independant 3D tiles server reusing py3dtiles, or
integrate this as QGIS Server module if we want.
We would be happy to work on these subjects and share our experience on
all 3D-related topics. Funding is also very welcome.
But for now, I think we should focus on releasing QGIS3 in a usable
state. We have waited for too long, and there is still work to achieve
to stabilize the release.
3D features can wait a bit more, even if call for interest, needs,
funding and collaboration is welcome.
Best regards,
Vincent
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171109/983e9e87/attachment.html>
