[QGIS-Developer] Python error on start up from GRASS processing
Tim Sutton
tim at kartoza.com
Thu Nov 9 11:28:09 PST 2017
Hi
Its great to see the GRASS stuff merged now. However it gives me an error on startup:
An error has occurred while executing Python code:
TypeError: QgsProcessingAlgorithm.addParameter(): argument 1 has unexpected type 'ParameterRaster'
File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/algs/grass7/Grass7Algorithm.py", line 170, in initAlgorithm
res = self.addParameter(p, True)
Python version: 3.6.2 (default, Jul 17 2017, 16:44:45) [GCC 4.2.1 Compatible Apple LLVM 8.1.0 (clang-802.0.42)]
QGIS version: 2.99.0-Master Master, 2c1e2014d7
Python Path:
/Users/timlinux/Library/Application Support/QGIS/QGIS3/profiles/default/python
/Users/timlinux/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins
/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/bin/$PYTHONPATH
/usr/local/opt/gdal2-python/lib/python3.6/site-packages
/usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python36.zip
/usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6
/usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload
/usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages
/usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/pycharm-debug-py3k.egg
Does anyone else get this?
Regards
Tim
Tim Sutton
Co-founder: Kartoza
Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net
Kartoza is a merger between Linfiniti and Afrispatial
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171109/6eb879ef/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171109/6eb879ef/attachment-0001.jpg>
