[QGIS-Developer] Python error on start up from GRASS processing
Tim Sutton tim at kartoza.com
Thu Nov 9 14:00:49 PST 2017
Hi
Thanks Médéric - cleaning out my build dir fixed the issue.
Regards
Tim
> On 09 Nov 2017, at 22:18, Médéric Ribreux <mederic.ribreux at medspx.fr> wrote:
> Le 2017-11-09 20:28, Tim Sutton a écrit :
>> Hi
>> Its great to see the GRASS stuff merged now. However it gives me an
>> error on startup:
>> An error has occurred while executing Python code:
>> TypeError: QgsProcessingAlgorithm.addParameter(): argument 1 has
>> unexpected type 'ParameterRaster'
>> Traceback (most recent call last):
>>  File
>> "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/algs/grass7/Grass7Algorithm.py",
>> line 170, in initAlgorithm
>>    res = self.addParameter(p, True)
>> Python version: 3.6.2 (default, Jul 17 2017, 16:44:45) [GCC 4.2.1
>> Compatible Apple LLVM 8.1.0 (clang-802.0.42)]
>> QGIS version: 2.99.0-Master Master, 2c1e2014d7
>> Python Path:
>> 	* /Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python
>> 	* /Users/timlinux/Library/Application
>> Support/QGIS/QGIS3/profiles/default/python
>> Support/QGIS/QGIS3/profiles/default/python/plugins
>> 	* /Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins
>> /Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/bin/$PYTHONPATH
>> 	* /usr/local/opt/gdal2-python/lib/python3.6/site-packages
>> /usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python36.zip
>> /usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6
>> /usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload
>> /usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages
>> /usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/pycharm-debug-py3k.egg
>> Does anyone else get this?
>> Regards
>> Tim
>> TIM SUTTON
>> CO-FOUNDER: Kartoza
>> PROJECT CHAIR: QGIS.org <http://qgis.org/> [1]
>> Visit http://kartoza.com <http://kartoza.com/> [2] to find out about open source:
>> Desktop GIS programming services
>> Geospatial web development
>> GIS Training
>> Consulting Services
>> SKYPE: timlinux
>> IRC: timlinux on #qgis at freenode.net <http://freenode.net/> [3]
>> Kartoza is a merger between Linfiniti and Afrispatial
>> Links:
>> [1] http://QGIS.org <http://qgis.org/>
>> [2] http://kartoza.com/ <http://kartoza.com/>
>> [3] http://freenode.net <http://freenode.net/>
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Hello,
> I can't reproduce on a fresh master build. It seems that you are using some old description files (ParameterRaster has been transformed to QgsProcessingParameterRaster).
> I think you need to either start from a clean/new build directory or a new install directory...
> Cheers,
> Médéric RIBREUX
> https://medspx.fr <https://medspx.fr/>
Tim Sutton
Co-founder: Kartoza
Project chair: QGIS.org
Visit http://kartoza.com <http://kartoza.com/> to find out about open source:
GIS Training
Consulting Services
Skype: timlinux
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171110/2d2fd488/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171110/2d2fd488/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
