[QGIS-Developer] Processing Split with lines algorithm broken
G. Allegri giohappy at gmail.com
Wed Nov 15 02:27:29 PST 2017
I also agree to step back to single-part output.
giovanni
2017-11-15 11:13 GMT+01:00 Alexandre Neto <senhor.neto at gmail.com>:
> +1
> Nathan Woodrow <madmanwoo at gmail.com> escreveu no dia quarta, 15/11/2017
> às 05:10:
>> IMO go with the principle of least astonishment.  I think the expected
>> outcome is single part features as it's not clear that you need to run
>> another step.
>> - Nathan
>> On Wed, Nov 15, 2017 at 2:48 PM, Nyall Dawson <nyall.dawson at gmail.com>
>> wrote:
>>> On 15 November 2017 at 00:33, matteo <matteo.ghetta at gmail.com> wrote:
>>> > Hi devs,
>>> > the algorithm Split with lines seems not working. No output error but
>>> > both lines or polygons in output are not split. The same algorithm with
>>> > the same data works in QGIS 2.18
>>> I suspect it's working OK, but you're hitting a change in 3.0 where
>>> the output of this algorithm is a multi-line, with the individual
>>> split parts still forming a single feature. You need to run multiparts
>>> to singleparts on it afterward.
>>> ....However....
>>> This was a change I requested in
>>> https://github.com/qgis/QGIS/pull/3798, since it seemed like a logical
>>> move. Having used this algorithm extensively since (and also been
>>> confused in thinking that the algorithm was broken!) I'm not convinced
>>> this was the right move anymore, and think that we should probably
>>> always output single-part features from this algorithm.
>>> What's everyone's thoughts?
>>> Nyall
>>> QGIS-Developer mailing list
>>> QGIS-Developer at lists.osgeo.org
>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alexandre Neto
> @AlexNetoGeo
> http://sigsemgrilhetas.wordpress.com
> http://gisunchained.wordpress.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171115/84257d1f/attachment.html>
More information about the QGIS-Developer mailing list
