[QGIS-Developer] Preview job and slow datasources
    Even Rouault
    even.rouault at spatialys.com
    Wed Nov 15 06:56:42 PST 2017
I'm working currently on improving raster performance per
https://github.com/qgis/QGIS/pull/5632 , and while testing with a variety of GDAL
datasources, I found that the "preview job" (*) mechanism that is currently enabled on the
main canvas (pre-rendering the 8 zones around the canvas extent) can have adverse
performance impact with very slow datasources. Particularly those doing network accesses,
where the bandwidth consumed by the preview jobs prevents the main rendering job to
being served first (due to the fact the the preview jobs of the previous interaction are not
immediately cancelled by the next one since, because being busy in libcurl calls)
Wouldn't it make sense to offer an option to disable preview jobs on the main canvas for such
use case ?
I guess this could also be useful for complex projects with many layers of "fast datasources",
but where the global rendering time is large.
A clever variant would measure the execution time of those preview jobs, and if, for example,
it is above the 250 ms delay  in which they are fired by
QgsMapCanvas::schedulePreviewJob(), it would automatically disable it (potentially,
temporarily, until the number of layers changes). In the case I mentionned above, each
preview job takes several seconds to complete.
Or a simpler alternative would be to schedule the next preview job after the previous
preview job has completed (instead of starting them every 250 ms).  This would not be
completely ideal with my above mentionned network case, compared to completely disabling
preview jobs, but that could be a reasonable compromise, and would limit the CPU load of
preview jobs to at most one core (currently if the preview jobs run slowly, they can "eat" up
to 8 cores, since they are 8 preview jobs)
Thoughts ?
Even
(*) added per
https://github.com/qgis/qgis/commit/2d531e5814c1b43a23c36d09ace9a5f5729e5bb4
http://www.spatialys.com
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171115/3ee1cea9/attachment.html>
