[QGIS-Developer] Preview job and slow datasources
Patrick Dunford enzedrailmaps at gmail.com
Wed Nov 15 18:35:48 PST 2017
What is this "preview job" function?
On 16/11/17 03:56, Even Rouault wrote:
> Hi,
> I'm working currently on improving raster performance per
> https://github.com/qgis/QGIS/pull/5632 , and while testing with a
> variety of GDAL datasources, I found that the "preview job" (*)
> mechanism that is currently enabled on the main canvas (pre-rendering
> the 8 zones around the canvas extent) can have adverse performance
> impact with very slow datasources. Particularly those doing network
> accesses, where the bandwidth consumed by the preview jobs prevents
> the main rendering job to being served first (due to the fact the the
> preview jobs of the previous interaction are not immediately cancelled
> by the next one since, because being busy in libcurl calls)
> Wouldn't it make sense to offer an option to disable preview jobs on
> the main canvas for such use case ?
> I guess this could also be useful for complex projects with many
> layers of "fast datasources", but where the global rendering time is
> large.
> A clever variant would measure the execution time of those preview
> jobs, and if, for example, it is above the 250 ms delay in which they
> are fired by QgsMapCanvas::schedulePreviewJob(), it would
> automatically disable it (potentially, temporarily, until the number
> of layers changes). In the case I mentionned above, each preview job
> takes several seconds to complete.
> Or a simpler alternative would be to schedule the next preview job
> after the previous preview job has completed (instead of starting them
> every 250 ms). This would not be completely ideal with my above
> mentionned network case, compared to completely disabling preview
> jobs, but that could be a reasonable compromise, and would limit the
> CPU load of preview jobs to at most one core (currently if the preview
> jobs run slowly, they can "eat" up to 8 cores, since they are 8
> preview jobs)
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171116/d608e02c/attachment-0001.html>
More information about the QGIS-Developer mailing list
