[QGIS-Developer] Deploy plugin by setting QGIS_PLUGINPATH
Richard Duivenvoorde rdmailings at duif.net
Thu Nov 16 04:25:10 PST 2017
I think what Zhang Qun is asking if he can use a custom directory to
store his plugin in.
If I grep in the source dir of QGIS I see a lot of references to
QGIS_PLUGINPATH, so it should work.
I also see in the changelog that is there since 2010 (and a lot of fixes
for windows environments....)
Do you seen the QGIS_PLUGINPATH in the Options/System tab?
Also does it not show up in the plugin list of the plugin manager?
Because if you install a plugin by copying it to the plugin dir (even
the default one), it is not enabled by default. So IF shown, enable it
in the plugin manager first.
FYI: grepping:
grep -ir QGIS_PLUGINPATH *
Binary file
build/src/python/CMakeFiles/qgispython.dir/qgspythonutilsimpl.cpp.o matches
build/doc/news:- Support for custom plugin directories using
QGIS_PLUGINPATH environment
build/doc/news.html:<LI>Support for custom plugin directories using
Binary file build/output/lib/libqgispython.so.2.18.14 matches
ChangeLog:    Fix windows path escaping for QGIS_PLUGINPATH
ChangeLog:    skip empty parts of QGIS_PLUGINPATH
ChangeLog:    don't split QGIS_PLUGINPATH at colon on windows
ChangeLog:    Additionally, plugin paths in QGIS_PLUGINPATH can be
separated by either semicolon or colon.
ChangeLog:    [FEATURE] support for custom plugin directories using
QGIS_PLUGINPATH environment variables.
doc/news.t2t:- Support for custom plugin directories using
NEWS:- Support for custom plugin directories using QGIS_PLUGINPATH
environment
src/python/qgspythonutilsimpl.h:    //! return a list of extra plugins
paths passed with QGIS_PLUGINPATH environment variable
src/python/qgspythonutilsimpl.cpp:  // plugin dirs passed in
QGIS_PLUGINPATH env. variable have highest priority (usually empty)
src/python/qgspythonutilsimpl.cpp:  const char* cpaths = getenv(
"QGIS_PLUGINPATH" );
tests/src/python/test_qgsappstartup.py:            # when it is started.
if QGIS_PLUGINPATH is correctly parsed, this
env={'QGIS_PLUGINPATH': testDir})
HTH,
Richard DUivenvoorde
On 16-11-17 11:47, Patrick Dunford wrote:
> There are sometimes reasons why this method may not work (I think Ubuntu
> does have a particular limitation in this regard)
> One option is you can create a shortcut on the menu and pass the
> variable value in that shortcut.
> For example one of the Qgis shortcuts on the Whiskers menu in XFCE on my
> computer uses this command to start a version of Qgis that I built from
> source and installed to a different path:
> env LD_LIBRARY_PATH=/home/patrick/apps/lib /home/patrick/apps/bin/qgis
> where env is passing that variable into the environment that Qgis starts
> with.
> On 16/11/17 23:33, Zhang Qun wrote:
>> Dear all,
>> I want to use the |QGIS_PLUGINPATH| environment variable to point to
>> the directory where my plugin are located but did not manage to get it
>> work.
>> I'm on Ubuntu16.04 and running QGIS 2.18.
>> I set the variable in terminal by:
>> $ export QGIS_PLUGINPATH=~/QGIS_Plugins/rndf-editor/RNDFEditor/
>> and launch the QGIS in this terminal (I guess in order to get the
>> variable effective I have to run within the terminal right?)
>> $ qgis
>> But my plugin still did not get to show under the manu Plugin.
>> Can anyone advise me the correct way to do it? Thanks.
>> Best regards,
>> Zhang Qun
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
