[QGIS-Developer] Preview job and slow datasources
Patrick Dunford enzedrailmaps at gmail.com
Thu Nov 16 18:53:21 PST 2017
With the second command
iface.mapCanvas().setPreviewJobsEnabled(False)
when I run that command it drops back to 16 GB
On 16/11/17 23:15, Matthias Kuhn wrote:
> Hi Patrick,
> Would be interesting to do this test with previews enabled and
> disabled. Then we'll see if it's actually the previews or some other
> mechanism that is causing this.
> IIRC only a composite image is saved in the preview jobs and not each
> layer separately, but that's just what I remember and not evidence based.
> You can enable them in the python console with
>     iface.mapCanvas().setPreviewJobsEnabled(True)
> and disable with
> Thanks for a feedback
> Matthias
> On 11/16/2017 08:42 AM, Patrick Dunford wrote:
>> In my current project using Qgis 2.99, turning off the rasters uses
>> 16 GB, turning them on uses 52 GB
>> I do not believe it is independent from the number of layers that are
>> being displayed.
>> Previous versions of the software did not cache every single raster
>> (the number of rasters actually being displayed on the canvas at any
>> one time is a small fraction of the total number in the project)
>> On 16/11/17 20:11, Matthias Kuhn wrote:
>>> Hi Patrick,
>>> This uses some memory (~ canvas width pixels * canvas height pixels
>>> * 8 preview images * 32 bit RGBA), so let's assume 50 MB to 100 MB.
>>> This consumption is independent from the number or type of layers.
>>> Matthias
>>> On 11/16/2017 08:02 AM, Patrick Dunford wrote:
>>>> So to put it another way this is the reason why Qgis wants to use a
>>>> huge amount of memory (40 GB) when I have a lot of raster images
>>>> loaded in the background.
>>>> On 16/11/17 18:56, Tim Sutton wrote:
>>>>> Hi
>>>>>> On 16 Nov 2017, at 04:35, Patrick Dunford
>>>>>> <enzedrailmaps at gmail.com <mailto:enzedrailmaps at gmail.com>> wrote:
>>>>>> What is this "preview job" function?
>>>>> Its application logic to prefetch / pre-render offscreen content
>>>>> in anticipation of user panning the map.
>>>>> Regards
>>>>> Tim
>>>>>> _______________________________________________
>>>>>> QGIS-Developer mailing list
>>>>>> QGIS-Developer at lists.osgeo.org
>>>>>> <mailto:QGIS-Developer at lists.osgeo.org>
>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>> *Tim Sutton*
>>>>> *Co-founder:*Kartoza
>>>>> *Project chair:*QGIS.org <http://QGIS.org>
>>>>> Visit http://kartoza.com <http://kartoza.com/> to find out about
>>>>> open source:
>>>>> Desktop GIS programming services
>>>>> Geospatial web development
>>>>> GIS Training
>>>>> Consulting Services
>>>>> *Skype*: timlinux
>>>>> *IRC:*timlinux on #qgis at freenode.net <http://freenode.net>
>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171117/448c25ac/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171117/448c25ac/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
