[QGIS-Developer] Deploy plugin by setting QGIS_PLUGINPATH
Zhang Qun
zhangq.rhy at gmail.com
Thu Nov 16 19:15:26 PST 2017
Hi Borys, thanks for your kind reply and your advice setting the variable
pointing to its parent folder of the plugin worked.
I also found I need to check the plugin manager list before my plugin can
show in the menu. The plugin manager somehow loaded the plugin while I
check the list.
Thank you a million.
Best regards,
Zhang Qun
On Thu, Nov 16, 2017 at 10:13 PM, Borys Jurgiel <lists at borysjurgiel.pl>
wrote:
> I'm sorry for the messy reply made by my wonderful kmail5 ;p
> The first paragraph is outdated - I checked and it works. The second is an
> alternative solution, and the direct response to your question is on the
> end.
> Regards,
> Borys
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171117/15523d5e/attachment.html>
