[QGIS-Developer] Preview job and slow datasources
Patrick Dunford enzedrailmaps at gmail.com
Thu Nov 16 23:21:48 PST 2017
Most of them are geoJpeg, there are a smaller number of geoTiff
On 17/11/17 20:10, Matthias Kuhn wrote:
> Thanks, that's an interesting information.
> What datatype are your rasters?
> On 11/17/2017 03:53 AM, Patrick Dunford wrote:
>> With the second command
>> iface.mapCanvas().setPreviewJobsEnabled(False)
>> when I run that command it drops back to 16 GB
>> On 16/11/17 23:15, Matthias Kuhn wrote:
>>> Hi Patrick,
>>> Would be interesting to do this test with previews enabled and
>>> disabled. Then we'll see if it's actually the previews or some other
>>> mechanism that is causing this.
>>> IIRC only a composite image is saved in the preview jobs and not
>>> each layer separately, but that's just what I remember and not
>>> evidence based.
>>> You can enable them in the python console with
>>>     iface.mapCanvas().setPreviewJobsEnabled(True)
>>> and disable with
>>> Thanks for a feedback
>>> Matthias
>>> On 11/16/2017 08:42 AM, Patrick Dunford wrote:
>>>> In my current project using Qgis 2.99, turning off the rasters uses
>>>> 16 GB, turning them on uses 52 GB
>>>> I do not believe it is independent from the number of layers that
>>>> are being displayed.
>>>> Previous versions of the software did not cache every single raster
>>>> (the number of rasters actually being displayed on the canvas at
>>>> any one time is a small fraction of the total number in the project)
>>>> On 16/11/17 20:11, Matthias Kuhn wrote:
>>>>> Hi Patrick,
>>>>> This uses some memory (~ canvas width pixels * canvas height
>>>>> pixels * 8 preview images * 32 bit RGBA), so let's assume 50 MB to
>>>>> 100 MB.
>>>>> This consumption is independent from the number or type of layers.
>>>>> Matthias
>>>>> On 11/16/2017 08:02 AM, Patrick Dunford wrote:
>>>>>> So to put it another way this is the reason why Qgis wants to use
>>>>>> a huge amount of memory (40 GB) when I have a lot of raster
>>>>>> images loaded in the background.
>>>>>> On 16/11/17 18:56, Tim Sutton wrote:
>>>>>>> Hi
>>>>>>>> On 16 Nov 2017, at 04:35, Patrick Dunford
>>>>>>>> <enzedrailmaps at gmail.com <mailto:enzedrailmaps at gmail.com>> wrote:
>>>>>>>> What is this "preview job" function?
>>>>>>> Its application logic to prefetch / pre-render offscreen content
>>>>>>> in anticipation of user panning the map.
>>>>>>> Regards
>>>>>>> Tim
>>>>>>>> _______________________________________________
>>>>>>>> QGIS-Developer mailing list
>>>>>>>> QGIS-Developer at lists.osgeo.org
>>>>>>>> <mailto:QGIS-Developer at lists.osgeo.org>
>>>>>>>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>>>> Unsubscribe:
>>>>>>> *Tim Sutton*
>>>>>>> *Co-founder:*Kartoza
>>>>>>> *Project chair:*QGIS.org <http://QGIS.org>
>>>>>>> Visit http://kartoza.com <http://kartoza.com/> to find out about
>>>>>>> open source:
>>>>>>> Desktop GIS programming services
>>>>>>> Geospatial web development
>>>>>>> GIS Training
>>>>>>> Consulting Services
>>>>>>> *Skype*: timlinux
>>>>>>> *IRC:*timlinux on #qgis at freenode.net <http://freenode.net>
>>>>>> List info:https://lists.osgeo.org/mailman/listinfo/qgis-developer
>>>>>> Unsubscribe:https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171117/fe9b2051/attachment-0001.html>
Type: image/jpeg
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171117/fe9b2051/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
