[QGIS-Developer] QGIS Server plugins and thread safety
Luigi Pirelli
luipir at gmail.com
Sun Nov 19 02:26:22 PST 2017
I didn't follow, shared cache is a solved problem for the server?
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 19 November 2017 at 10:34, Alessandro Pasotti <apasotti at gmail.com> wrote:
> Hi,
> mi recent experiments with multi-threaded python wrappers for QGIS server
> showed a critical flaw in my original implementation of the server plugins.
> First, I want to stress that this is not a problem in FCGI server
> implementation but only if the server is used directly from python in a
> multi threaded server implementation.
> The problem is that the server interface that exposes the request handler is
> a static property of the interface, that is changed on every request.
> This means that there is a race condition in setting/accessing the handler
> from a plugin filter, and that a plugin filter might access to the handler
> for a wrong request.
> The solution is to pass the request handler (or the request and/or response
> objects depending on the filter) to the plugin filters and leave the
> interface for static properties only.
> This would be a big API change for the server interface and filters and I'm
> not sure we have time/resources to do that now.
> As an alternative we could simply document the issue and change the testing
> code to create a new server instance to server every request (to be
> verified, and with consitent performance degradation).
> What's your opinion about this issue?
> BTW, tomorrow I'll file a ticket for this problem.
> Alessandro Pasotti
> w3: www.itopen.it
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
