[QGIS-Developer] OTF layer reprojection not working in latest master ?
Patrick Dunford enzedrailmaps at gmail.com
Sun Nov 19 23:24:04 PST 2017
Oh, I'm just giving you the opportunity to say "this is not a bug, it's
expected the project file format has changed" or something like that?
On 20/11/17 20:22, Andreas Neumann wrote:
> Hi Patrick,
> Can you please file an issue report and provide some sample data and
> project to demonstrate the issue?
> It would help the devs to fix this issue, if it is reproducible.
> Thanks,
> Andreas
> On 2017-11-20 08:18, Patrick Dunford wrote:
>> I have a project that (I just discovered) has some layers in EPSG 4326,
>> the project is EPSG 3857
>> When I changed the project from EPSG 4326 to EPSG 3857 these layers were
>> being reprojected on the fly, all the others were resaved into EPSG 3857
>> Everything has been working fine on 2.14, 2.16, 2.18 and all the masters
>> up till now, when I just installed the latest master f1c3692. these
>> layers are not visible in the canvas. I assume this must be an issue
>> with OTF reprojection. All the other layers that don't rely on OTF are
>> displayed.
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171120/9af2249b/attachment.html>
More information about the QGIS-Developer mailing list
