[QGIS-Developer] Refactor Fields: save and load mapping configuration
Régis Haubourg
regis.haubourg at gmail.com
Thu Nov 23 04:48:47 PST 2017
2017-11-23 13:35 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
> Hi Régis,
> I agree - it would be good to brainstorm what's missing to have an
> FME-like ETL environment.
> I see that you are coming to the Madeira dev meeting. Would be a good
> opportunity for such discussions and then open the QEP in parallel (or open
> it before and work on it).
Yep! Do we have already a place in the wiki to
> BTW: refactor fields isn't such a bad name in my opinion. Perhaps we could
> introduce aliases for algorithms - so that they could be found more easily?
> Greetings,
> Andreas
> On 2017-11-23 09:12, Régis Haubourg wrote:
> Hi Andreas,
> I don't have any answer to that particular question, but in many project
> we are working for, it becomes clear that we need to push processing to
> become an ETL, and the field mapping component is clearly a key feature.
> What do you think about opening a QEP and store in there all what's
> currently missing for a clean and easy workflow?
> We clearly will have some funders in 2018.
> I see :
> # Mapping field alg:
> - rename it to something more easy to find. What about "Field matcher" ?
> - automap fields using tolerant expression based on heuristics (unaccent,
> lowercase, soundhex or whatever, field order.. )
> - save and restore config.
> - Auto restore for same table names
> - And, the key for fame, a graphical component for field matching,
> because this is what we all want :)
> # database writer :
> - finely control all SQL options: drop table / recreate / truncate /
> insert / update with where clause
> - add rollback option to just try without commiting
> - return all database logs in details
> Opinions?
> Régis
> 2017-11-23 9:01 GMT+01:00 Andreas Neumann <a.neumann at carto.net>:
>> Hi,
>> The refactor fields algorithm is potentially very powerful.
>> However, I do miss a way to save and load the configuration (or maybe I
>> just haven't found it). I have layers with many fields and I am adding
>> additional fields with expressions.
>> Every time I run it, I have to do the configuration again and again. Is
>> there a way to save and load the mapping configuration? It would save me a
>> lot of time!
>> Thanks,
>> Andreas
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171123/7eb1b633/attachment.html>
