[QGIS-Developer] QGIS Server request extra parameters as variables for expressions
Arnaud Morvan
arnaud.morvan at camptocamp.com
Thu Nov 23 07:46:57 PST 2017
@Patrick :
Yes, I know that it is possible to use FILTER in request, but I'm not
sure all layers will have the same field name for "floor".
So I would prefer to define a filter in each layer definition in the
project file using a common variable name.
And I would like to have the same behavior on desktop side (using a UI
plugin that set the variable value and refresh the canvas).
@Mathias :
Yes after taking a look, WMS dimensions is exactly the idea I have in mind.
In mapserver documentation about WMS dimension I see that the dimension
field is defined in each layer.
LAYER
NAME "lakes_elev"
METADATA
"wms_title" "Lakes"
"wms_description" "Lakes"
"wms_dimensionlist" "elevation, text_dimension"
"wms_elevation_item" "ELEV"
"wms_elevation_extent" "500, 490, 480"
"wms_elevation_units" "meters"
"wms_elevation_default" "500"
"wms_text_dimension_item" "text_dimen"
"wms_text_dimension_extent" "first, second, third"
"wms_text_dimension_units" "my_units"
"wms_enable_request" "*"
END
TYPE POLYGON
END
Is there something about WMS dimensions in QGIS server roadmap ?
For now we do it in mapserver using normal template variables, for
example :
LAYER
VALIDATION
"floor" "[+-][0-9A]+"'
END
DATA "geom FROM (SELECT * FROM mytable WHERE etage = '%floor%' OR
etage IS NULL OR '%floor%' = 'NULL') AS foo USING UNIQUE id USING srid=3945"
END
Note that here the default is no filter at all (all features displayed
when the parameter is missing), and features with etage == NULL are
displayed on all floors.
Arnaud Morvan
Ingénieur logiciel
Tél: +33 (0)4 58 48 20 32
Camptocamp France SAS
18 rue du Lac Saint André
Savoie Technolac - Bâtiment Le Dauphin
F-73370 Le Bourget du Lac
http://www.camptocamp.com
Le 23/11/2017 à 14:49, Patrick Valsecchi a écrit :
> You could do that using the filter parameter with something like that:
> FILTER=layer_name:"floor" = 3
> On Thu, Nov 23, 2017 at 2:38 PM, Matthias Kuhn <matthias at opengis.ch
> <mailto:matthias at opengis.ch>> wrote:
> Like WMS dimension?
> http://mapserver.org/ogc/wms_dimension.html
> <http://mapserver.org/ogc/wms_dimension.html>
> Matthias
> On 11/23/17 2:11 PM, Arnaud Morvan wrote:
> > Hello,
> > I would like GetMap and GetFeature request extra parameters to be
> > accessible as variables in server.
> > So we could define, in QGIS project, a variable "floor", used to
> > filter layers.
> > On desktop side, we could have a desktop plugin named FloorSlider to
> > change the "floor" value.
> > And on the server side, the floor value could be passed as extra
> > parameter.
> > So it would be easy to handle multi-floor layers in a project file.
> > Arnaud Morvan
> > Ingénieur logiciel
> > Tél: +33 (0)4 58 48 20 32 <tel:%2B33%20%280%294%2058%2048%2020%2032>
> > Le 22/11/2017 à 18:05, René-Luc Dhont a écrit :
> >> Hi Arnaud,
> >> Is it like updated a QGIS project variables ?
> >> Regards,
> >> René-Luc
> >> Le 22/11/2017 à 15:31, Arnaud Morvan a écrit :
> >>> Hello,
> >>> With mapserver, request extra parameters are accessible as
> template
> >>> variables in mapfile.
> >>> I would like to implement the same possibility in QGIS Server,
> extra
> >>> parameters may be accessible in project as expression variables.
> >>> For example : I would like to pass in a GetMap request an extra
> >>> parameter FLOOR.
> >>> This parameter could be handled by QGIS Server as a variable
> value,
> >>> so this could be used in the project to filter some layers
> using an
> >>> expression.
> >>> Do you think this could be acceptable directly in QGIS Server, or
> >>> may I have to wrote a plugin.
> >>> Maybe this type of plugin already exists ?
> >>> Note that I'm not familiar with server part.
> >>> Best regards
> >> _______________________________________________
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org
> <mailto:QGIS-Developer at lists.osgeo.org>
> >> List info:
> https://lists.osgeo.org/mailman/listinfo/qgis-developer
> <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> >> Unsubscribe:
> > List info:
> > Unsubscribe:
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe:
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171123/840476c7/attachment-0001.html>
