[QGIS-Developer] QGIS Server request extra parameters as variables for expressions
René-Luc Dhont
rldhont at gmail.com
Fri Nov 24 02:02:19 PST 2017
@Arnaud:
There is no WMS dimensions in QGIS server roadmap
@Richard:
Which one of the three GeoServer implementation is the more 'common' way ?
To my point of view, having the capability to update QGIS Variables
through HTTP parameters will be a great enhancement.
About the WMS dimensions, QGIS will need some enhancement about Raster
data to apply filtering, changes band in style and/or use expression for
styles.
Regards,
René-Luc
Le 23/11/2017 à 20:53, Richard Duivenvoorde a écrit :
> On 23-11-17 16:46, Arnaud Morvan wrote:
>> @Mathias :
>> Yes after taking a look, WMS dimensions is exactly the idea I have in mind.
> Mmm,
> I think Dimensions is a different case, as Dimensions are tied to WMS-T
> [0] and the query parameter is defined as
> &TIME=...,...
> &TIME=...
> etc
> OR elevation:
> &ELEVATION=
> GeoServer has (besides dimensions) even some more use of 'variables'
> which you can use in different places:
> - possible variable substitutions in sld's [1]
> &&env=name1:value1;name2=value2&...
> - sql view parameters [2]
> &viewparams=p1:v1;p2:v2;...
> - format options in CQL queries [3]
> &format_options=param1:value1;param2:value2;...
> I think the 'expressions'-variables you are talking about are most close
> to the viewparams (though if it only filters the styling itis a sld one...).
> My point: let's define a 'common' param, shared between different FOSS
> wms's instead of coming up with our own wheel :-)
> Regards,
> [0]
> https://anitagraser.com/2011/06/10/wms-t-support-in-geoserver-and-mapserver/
> [1]
> http://docs.geoserver.org/stable/en/user/styling/sld/extensions/substitution.html
> [2] http://docs.geoserver.org/latest/en/user/data/database/sqlview.html
> [3] http://docs.geoserver.org/latest/en/user/services/wfs/vendor.html
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
