[QGIS-Developer] GRASS r.walk
Joshua Quesenberry engnfrc at gmail.com
Fri Nov 24 07:03:03 PST 2017
Thanks Paulo, I hadn’t thought of that and will give it a try next.
Josh Q
From: Paulo van Breugel [mailto:p.vanbreugel at gmail.com]
Sent: Friday, November 24, 2017 5:04 AM
To: Joshua Quesenberry <engnfrc at gmail.com>
Cc: qgis-developer at lists.osgeo.org
Subject: Re: [QGIS-Developer] GRASS r.walk
Hi Josh,
I would suggest to send questions to the grass user and/or developers list (https://grass.osgeo.org/support/mailing-lists/).
Best wishes,
Paulo
On Thu, Nov 23, 2017 at 9:50 PM, Joshua Quesenberry <engnfrc at gmail.com <mailto:engnfrc at gmail.com> > wrote:
Is it normal for an r.walk over an area of 10,500 acres to use up 12GB of HD space and want more? That’s using up every bit of space I have left, so it’s crashing out. I tried setting the maximum cost to 10 and I think 1 also, but the algorithm keeps running for a long time making these really large files…
Thanks,
Josh Q
From: Joshua Quesenberry [mailto:engnfrc at gmail.com <mailto:engnfrc at gmail.com> ]
Sent: Thursday, November 23, 2017 12:05 PM
To: qgis-developer at lists.osgeo.org <mailto:qgis-developer at lists.osgeo.org>
Cc: engnfrc at gmail.com <mailto:engnfrc at gmail.com>
Subject: GRASS r.walk
Happy Thanksgiving Everyone!
Who’s very familiar with GRASS r.walk? I’m finding some tutorials and man pages with examples but having trouble applying what I’ve found. I’m trying to create mobility models for use with lost person analytics.
Does is matter what format the input layers are in? Should they all be UTM since that’s in meters? Or is it smart enough to mix and match WGS84 and UTM layers? And along the same lines, does my DEM need to have cells in meters? Most of what I get comes native in WGS84 with altitudes in feet, so if I don’t need to add extra steps converting to UTM and cells to meters that’s a good thing.
For the friction layer, the example on the man page appears to use landclass96 and only has 7 classifications… the NLCD 2011 land classification file I have has 30-40 classifications ranging from 11 to 95, does anyone have friction costs that can be applied to this data? Or at the very least some idea of the best method to use to come up with those values myself?
Thanks!
Josh Q
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171124/0b7c2556/attachment-0001.html>
More information about the QGIS-Developer mailing list
