[QGIS-Developer] Bookmarks severely broken. Unusable?
Richard Duivenvoorde
rdmailings at duif.net
Tue Nov 28 04:40:52 PST 2017
Hi Yves,
I have all kind of strange behaviours. As said: in master I can only
create one bookmark. And 'In Project' I cannot check.
But in 2.18.14 (only 2.18 I have) it is behaving strange too, looks like
it is depending on if you opening an existing project or not???
- I CAN check the check-boxes if I load an existing project
BUT the bookmark checked moves to the bottom then (sorting on??)
- I can NOT check the checkbox when I create a new project, then load
some data, save the project and add a bookmark.
- some project end up with a 0 srid (and are not usable anymore after that)
- after opening an existing project I can all at a sudden check the
check-boxes again (from other projects?), but IF I check those, I
actually delete them from my global bookmarks????
Apparently the 'In Project' means something like: save it in the
project, BUT remove it from the global bookmarks?
At least to me the behavior of all this is very counter-intuitive :-(
2.18, I do not care too much about it, but in Master it should work (and
preferably work intuitive :-) )...
Regards,
Richard
On 28-11-17 09:22, Yves Jacolin wrote:
> Hi,
> I did a quick test in my 2.18.11 instance of QGIS:
> * open an existing project
> * zoom somewhere and add a new bookmark, check "in project" checkbox
> * close the project, open a blank new project, do something
> * open again the previous project and test the spatial bookmark
> All worked as expected. I zoomed in the bookmark location and the "in
> project" bookmark disappear in a new project.
> Y.
> Le 28/11/2017 à 09:17, Richard Duivenvoorde a écrit :
>> Hi devs,
>> just a head up that currently (with me) the Spatial Bookmarks are
>> severely broken, both in master and 2.18.
>> Stuff which should have been introduced:
>> https://github.com/qgis/QGIS/pull/2661
>> do not work with me here locally.
>> Not even the basic adding of one bookmark.
>> Other issues:
>> https://issues.qgis.org/projects/qgis/search?utf8=%E2%9C%93&issues=1&q=bookmark
>> Can people confirm?
>> Though not that important in my view, I do not think we should ship
>> current implementation in a 3.0
>> Regards,
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
