[QGIS-Developer] Python error in processing on 2.99 startup
Stefan Blumentrath Stefan.Blumentrath at nina.no
Wed Nov 29 11:24:16 PST 2017
Hi Tim,
While your at GRASS provider in Processing: I noticed that it (still) uses linked OGR data (v.external).
However, that does not work for all algorithms and particularly not for all data types. Points are less of a problem, but areas are often. See:
https://lists.osgeo.org/pipermail/grass-dev/2017-November/086601.html
and
https://lists.osgeo.org/pipermail/grass-dev/2017-November/086505.html
v.external.out (https://grass.osgeo.org/grass72/manuals/v.external.out.html) might be used though instead of v.our.ogr. But there might be drawbacks too.
For raster data and algorithms r.external.out would speed-up the algorithms significantly…
Cheers
Stefan
From: QGIS-Developer [mailto:qgis-developer-bounces at lists.osgeo.org] On Behalf Of Tim Sutton
Sent: onsdag 29. november 2017 18.49
To: Larry Shaffer <larrys at dakotacarto.com>
Cc: QGIS Developer <qgis-developer at lists.osgeo.org>
Subject: Re: [QGIS-Developer] Python error in processing on 2.99 startup
Hi
Thanks for your quick reply Larry. Confirmed that your fix addresses the startup issue. When I try to run a grass processing alg on Mac I get a similar error in the log window now:
g.proj -c proj4="+proj=longlat +datum=WGS84 +no_defs"
v.external input="/Users/timlinux/gisdata/InaSAFE/Agung/Agung.shp" output="a5a1ef289ca1062" --overwrite -o
g.region n=-8.341999999999928 s=-8.341999999999928 e=115.50800000000004 w=115.50800000000004
v.buffer input=a5a1ef289ca1062 distance=100 tolerance=0.01 output=output0bddfa66df874fd7bb9e9d52a9c84228 --overwrite
v.out.ogr -c type=auto input="output0bddfa66df874fd7bb9e9d52a9c84228" output="/var/folders/g6/fnh1vyx13q728xq52nw7yx400000gn/T/processing_9b123312434544668360822a2b4cf6f0/0af610f60d9f465f9b2959fbc5442af5/output.shp" format=ESRI_Shapefile --overwrite
Traceback (most recent call last): File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/algs/grass7/Grass7Algorithm.py", line 375, in processAlgorithm Grass7Utils.executeGrass(self.commands, feedback, self.outputCommands) File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/algs/grass7/Grass7Utils.py", line 368, in executeGrass startupinfo=si if isWindows() else None File "/usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/subprocess.py", line 707, in __init__ restore_signals, start_new_session) File "/usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/subprocess.py", line 1333, in _execute_child raise child_exception_type(errno_num, err_msg) PermissionError: [Errno 13] Permission denied
Execution failed after 0.08 seconds
Loading resulting layers
Algorithm 'v.buffer.distance - Creates a buffer around features of given type.’ finished
I guess we are going to need to search and replace all shell=False parameters and set them to True if we are on Mac….
Regards
Tim
On 29 Nov 2017, at 19:40, Larry Shaffer <larrys at dakotacarto.com<mailto:larrys at dakotacarto.com>> wrote:
Hi Tim,
Ran into the same thing today, but with more output on the error:
PermissionError: [Errno 13] Permission denied: '/usr/local/opt/grass7/grass-base/etc/colors/grass'
Changing line # 108 in:
shell=False,
to:
shell=True if isMac() else False,
fixes the issue for me. Processing loads and GRASS algs open. (Not sure if True is needed for other platforms; untested.)
Fix not pushed. Please verify on your setup first (mine is macOS 10.11.6). Thanks!
Regards,
Larry Shaffer
Dakota Cartography
Black Hills, South Dakota
Boundless Desktop and QGIS Support/Development
Boundless Spatial - http://boundlessgeo.com<http://boundlessgeo.com/>
lshaffer at boundlessgeo.com<mailto:lshaffer at boundlessgeo.com>
On Wed, Nov 29, 2017 at 7:39 AM, Tim Sutton <tim at kartoza.com<mailto:tim at kartoza.com>> wrote:
Hi All
Its been a few days since I pulled from master - now I am getting the error below on startup. Does anyone else get it? (Building on MacOS here):
Couldn't load plugin 'processing' due to an error when calling its initGui() method
  File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/qgis/utils.py", line 345, in startPlugin
    plugins[packageName].initGui()
  File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/ProcessingPlugin.py", line 178, in initGui
    self.toolbox = ProcessingToolbox()
  File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/gui/ProcessingToolbox.py", line 93, in __init__
    self.fillTree()
  File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/gui/ProcessingToolbox.py", line 317, in fillTree
    self.fillTreeUsingProviders()
  File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/gui/ProcessingToolbox.py", line 382, in fillTreeUsingProviders
    providerItem = TreeProviderItem(provider, self.algorithmTree, self)
  File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/gui/ProcessingToolbox.py", line 513, in __init__
    self.setToolTip(0, self.provider.longName())
  File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/algs/grass7/Grass7AlgorithmProvider.py", line 122, in longName
    version = Grass7Utils.installedVersion()
  File "/Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing/algs/grass7/Grass7Utils.py", line 113, in installedVersion
Python version: 3.6.2 (default, Jul 17 2017, 16:44:45) [GCC 4.2.1 Compatible Apple LLVM 8.1.0 (clang-802.0.42)]
QGIS version: 2.99.0-Master Master, e8213b8e41
Python Path:
· /Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/python/plugins/processing
· /Users/timlinux/Library/Application Support/QGIS/QGIS3/profiles/default/python
· /Users/timlinux/Library/Application Support/QGIS/QGIS3/profiles/default/python/plugins
· /Users/timlinux/dev/cpp/QGIS-QtCreator-Build/output/bin/$PYTHONPATH
· /usr/local/opt/gdal2-python/lib/python3.6/site-packages
· /usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python36.zip
· /usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6
· /usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/lib-dynload
· /usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages
· /usr/local/opt/python3/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/pycharm-debug-py3k.egg
<KartozaNewLogoThumbnail.jpg>
Tim Sutton
Co-founder: Kartoza
Project chair: QGIS.org<http://qgis.org/>
Visit http://kartoza.com<http://kartoza.com/> to find out about open source:
Desktop GIS programming services
Geospatial web development
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net<http://freenode.net/>
QGIS-Developer mailing list
QGIS-Developer at lists.osgeo.org<mailto:QGIS-Developer at lists.osgeo.org>
List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
[cid:image001.jpg at 01D3694F.3956D080]
Tim Sutton
Co-founder: Kartoza
Project chair: QGIS.org<http://QGIS.org>
GIS Training
Consulting Services
Skype: timlinux
IRC: timlinux on #qgis at freenode.net<http://freenode.net>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171129/df00f89b/attachment-0001.html>
Type: image/jpeg
Desc: image001.jpg
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171129/df00f89b/attachment-0001.jpg>
More information about the QGIS-Developer mailing list
