[QGIS-Developer] QGIS Server 3 status
Régis Haubourg
regis.haubourg at gmail.com
Wed Oct 4 05:42:02 PDT 2017
Hi Matthias,
in my tests that were made a few month ago, it was a lot faster on project
load and a bit faster with parallel rendering for multi layer requests.
Still I found it still slower than desktop rendering on the very same
extent. I'm not aware of additional settings.
We did not have the opportunity to deploy a performance benchmark, maybe
Yves can tell us if things have moved on this front?
Régis
2017-10-04 14:15 GMT+02:00 Matthias Kuhn <matthias at opengis.ch>:
> Hi,
> I had some questions from people interested in performance.
> I advised them to set the following
> * QGIS_SERVER_PARALLEL_RENDERING=True
> * Trust project flag
> Apparently parallelized rendering works (system stats) but it was
> reported to be slower than older versions.
> Is there something else that needs to be done? Is there more information
> I can ask for / give?
> Thanks a lot
> Matthias
> On 10/04/2017 02:09 PM, René-Luc Dhont wrote:
> > Hi,
> > It seems that the QGIS refactoring is complete!
> > https://github.com/qgis/QGIS-Enhancement-Proposals/issues/74
> > https://github.com/qgis/qgis3.0_api/issues/57
> > https://github.com/qgis/QGIS/pull/4824
> > You can use QGIS Server like this in Python
> > from qgis.server import QgsServer, QgsServerRequest,
> > QgsBufferServerRequest, QgsBufferServerResponse
> > server = QgsServer()
> > qs = "?" + "&".join(["%s=%s" % i for i in list({
> > "MAP": '/tmp/qgis_project.qgs',
> > "SERVICE": "WFS",
> > "VERSION": "1.0.0",
> > "REQUEST": "GetCapabilities"
> > }.items())])
> > requestMethod = QgsServerRequest.GetMethod
> > headers = {}
> > data = '' #can be the xml request for requestMethod =
> > QgsServerRequest.PostMethod
> > request = QgsBufferServerRequest(qs, requestMethod, headers, data)
> > response = QgsBufferServerResponse()
> > server.handleRequest(request, response)
> > headers = []
> > rh = response.headers()
> > rk = sorted(rh.keys())
> > for k in rk:
> > headers.append(("%s: %s" % (k, rh[k])).encode('utf-8'))
> > body = bytes(response.body())
> > Now QGIS Server needs somes enhancement and cleanup.
> > René-Luc D'Hont
> > 3Liz
> > Le 04/10/2017 à 13:23, Régis Haubourg a écrit :
> >> Hi
> >> Yes, refactoring is now complete! see :
> 74#issuecomment-334123595
> >> Anita, I'll draft an article tonight if you still agree to review it,
> >> that would be great!
> >> Régis
> >> 2017-10-03 14:25 GMT+02:00 Anita Graser <anitagraser at gmx.at
> >> <mailto:anitagraser at gmx.at>>:
> >> On Tue, Oct 3, 2017 at 11:19 AM, Régis Haubourg
> >> <regis.haubourg at gmail.com <mailto:regis.haubourg at gmail.com>> wrote:
> >> Hi Etienne,
> >> from my point of view, this is the perfect time to start
> >> stressing QGIS server 3! We just discussed bout starting
> >> working with it this morning on a new project.
> >> Maybe Alessandro and René-Luc can tell us more about the
> >> plugin side.
> >> Paul is currently fixing issues raised by the OGC test
> >> engines. Richard, could you find some time to expose them on a
> >> public url?
> >> What would you think about publishing a QGIS Server update on
> >> blog.qgis.org <http://blog.qgis.org> once the latest information
> >> has been gathered? I'd like to see Server presented and advertised
> >> more widely.
> >> I'd be glad to help write the post if someone can help with the
> >> necessary insights.
> >> Regards,
> >> Anita
> >> _______________________________________________
> >> QGIS-Developer mailing list
> >> QGIS-Developer at lists.osgeo.org
> >> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> >> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171004/d1aede80/attachment.html>
