[QGIS-Developer] Processing random extract within subset
matteo matteo.ghetta at gmail.com
Fri Oct 6 05:27:01 PDT 2017
Hi guys,
I'm working with 2.18.3 and with the Processing algorithm "random
extract within subset". It seems that something is broken here.
The algorithm stops at the first subset found.
Same layer, same field and same algorithm in QGIS master works perfectly.
Should I open an issue for that?
Thanks
Cheers
Matteo
More information about the QGIS-Developer mailing list
