[QGIS-Developer] UI discussion?
Richard Duivenvoorde rdmailings at duif.net
Fri Oct 13 01:55:21 PDT 2017
Hi Dev's,
Should/can we plan some ui discussion maybe before QGIS3 freeze?
I know only discussion is not very helpfull, as it does not DO it, but I
think we should use the big 3 release as a handle to cleanup/fix some ui
too. As we add so much things, in my opinion you should not be afraid to
also remove (non used/important) things.
Some low hanging fruit I would like to do/discuss:
- move 'Plugins/Install plugin from zip' to the dialog
- remove overview panel (and menu actions)
- remove Help toolbar (we have helpbuttons and a menu item)
- move stuff (which I think clutter menu's but personally never use) to
'menu groups' (like all Save Map as.. and DXF import/export (and rename
those)
- merge Project New and New from Template to one 'menu group'-action
(with menu group I mean a button/action with a little dropdown next to
it, like you have for the select tools)
Opinions? Anybody interested?
Regards,
More information about the QGIS-Developer mailing list
