[QGIS-Developer] UI discussion?
Nathan Woodrow
madmanwoo at gmail.com
Fri Oct 13 01:56:30 PDT 2017
Remove overview panel?
On Fri., 13 Oct. 2017, 6:55 pm Richard Duivenvoorde, <rdmailings at duif.net>
wrote:
> Hi Dev's,
> Should/can we plan some ui discussion maybe before QGIS3 freeze?
> I know only discussion is not very helpfull, as it does not DO it, but I
> think we should use the big 3 release as a handle to cleanup/fix some ui
> too. As we add so much things, in my opinion you should not be afraid to
> also remove (non used/important) things.
> Some low hanging fruit I would like to do/discuss:
> - move 'Plugins/Install plugin from zip' to the dialog
> - remove overview panel (and menu actions)
> - remove Help toolbar (we have helpbuttons and a menu item)
> - move stuff (which I think clutter menu's but personally never use) to
> 'menu groups' (like all Save Map as.. and DXF import/export (and rename
> those)
> - merge Project New and New from Template to one 'menu group'-action
> (with menu group I mean a button/action with a little dropdown next to
> it, like you have for the select tools)
> Opinions? Anybody interested?
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171013/d4de15e9/attachment.html>
