[QGIS-Developer] UI discussion?
Tim Sutton
tim at kartoza.com
Fri Oct 13 05:24:44 PDT 2017
Hi
> On 13 Oct 2017, at 10:56, Nathan Woodrow <madmanwoo at gmail.com> wrote:
> Remove overview panel?
Yeah it is basically duplicated by multi canvas support now (except for AOI rectangle). +1 from me to remove it. Remember we must also remove the ‘hide/show in overview’ menu actions for legend items.
Regards
Tim
> On Fri., 13 Oct. 2017, 6:55 pm Richard Duivenvoorde, <rdmailings at duif.net <mailto:rdmailings at duif.net>> wrote:
> Hi Dev's,
> Should/can we plan some ui discussion maybe before QGIS3 freeze?
> I know only discussion is not very helpfull, as it does not DO it, but I
> think we should use the big 3 release as a handle to cleanup/fix some ui
> too. As we add so much things, in my opinion you should not be afraid to
> also remove (non used/important) things.
> Some low hanging fruit I would like to do/discuss:
> - move 'Plugins/Install plugin from zip' to the dialog
> - remove overview panel (and menu actions)
> - remove Help toolbar (we have helpbuttons and a menu item)
> - move stuff (which I think clutter menu's but personally never use) to
> 'menu groups' (like all Save Map as.. and DXF import/export (and rename
> those)
> - merge Project New and New from Template to one 'menu group'-action
> (with menu group I mean a button/action with a little dropdown next to
> it, like you have for the select tools)
> Opinions? Anybody interested?
> Regards,
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer <https://lists.osgeo.org/mailman/listinfo/qgis-developer>_______________________________________________
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171013/df94a098/attachment-0001.html>
