[QGIS-Developer] Re : PDF output and transparencies/blend modes
Jean-Roc Morreale (ml) jrmorreale_ml at enoreth.net
Wed Oct 18 11:53:48 PDT 2017
If this limit is still present, maybe the composer should ask the user
if he wants to defaut to a blendless export ? It would be similar to
the text option (glyph/shape) and avoid to the user to track down which
symbology level is using one.
regards,
jean-roc
Le mardi 17 octobre 2017 à 10:47 +0200, Andreas Neumann a écrit :
> Hi,
> QGIS 2x and qt 4.8 had the limitation, that as soon as the user
> introduced transparencies or blend modes, that the PDF output had to
> be rasterized.
> Is this still the case with qt 5.9x or did something improve along
> these lines? As far as I know, PDF supports both transparencies and
> blend modes also for vector objects.
> Thanks for a reply if someone knows,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
