[QGIS-Developer] Speed up building time after git checkout
Régis Haubourg
regis.haubourg at gmail.com
Mon Oct 30 03:29:35 PDT 2017
Huh thanks Nathan,
I realize that ccache was not installed even if I had created the symlinks
described in the INSTALL guide. I pushed a PR
https://github.com/qgis/QGIS/pull/5496
Cheers,
Régis
2017-10-29 1:27 GMT+02:00 Nathan Woodrow <madmanwoo at gmail.com>:
> Using ccache? That normally cuts down build times.
> On Sun., 29 Oct. 2017, 3:12 am , <delazj at gmail.com> wrote:
>> Hi,
>> I wrote almost the same message few days ago and forgot to send it. I'm
>> really interested in the answer of this, fed up with waiting so long
>> anytime i checkout a new branch, regardless the diff.
>> I didn't know the ˋninja qgisˋ command (used to ˋninja -j8ˋ as stated in
>> the install doc). Will give it a try.
>> Thanks to anyone who would help us... Le 28 oct. 2017 5:12 PM,
>> Pierre_Loicq <pierre.loicq at univ-tours.fr> a écrit :
>> > Hello,
>> > Does anyone know how to speed up my building time after a checkout ? It
>> > takes me 30 sec when I change just a file, with "ninja qgis"
>> > (https://nathanw.net/2016/05/26/speeding-up-qgis-build-
>> times-with-ninja/)
>> > but when I checkout it takes like more than 1 hour, with my 2 cores at
>> > 100%.
>> > Thank you
>> > Pierre
>> > Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-
>> f4099106.html
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20171030/aa62790f/attachment.html>
