[QGIS-Developer] Classification of values around zero
Pierre_Loicq
pierre.loicq at univ-tours.fr
Sat Sep 9 13:29:10 PDT 2017
Hello,
I added a new method of classification in the graduated methods (symbology).
It is aimed at plotting data that are centered on zero, with a class around
zero (like [-1,1] instead of [-1,0],[0,1] ), and with a colorbar that stay
symmetric around zero (for this I remove the extra classes). It uses the
prettyBreaks method. If data are all positive or negative, an alert box
appear.
https://github.com/qgis/QGIS/pull/5161
Hoping that you can include it in 3.0
Thank you
Pierre (Tours, France)
Pierre_Loicq wrote
> Hi,
> At the office, I often need to create map of modeled biases (float
> values), where it make sense to have a first class centered on zero
> (symbology/graduated). I learned C++ some months ago and would like to add
> this functionality as a first application, on the master branch.
> Pierre
Sent from: http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
