[QGIS-Developer] Problem with atlas rule-based styling
Andreas Neumann
a.neumann at carto.net
Thu Sep 14 09:34:45 PDT 2017
I use a rule-based styling to distinguish the feature is currently
active in Atlas from other features that aren't active.
This is my very simple rule:
$id = @atlas_featureid
The problem is when I close the atlas data sheet (print composer) - then
the symbology rule still remains active in the main map.
Is there a way around this problem? Can I detect if the print composer
atlas sheet is open or closed?
Thanks for any ideas,
Andreas
