[QGIS-Developer] Problem with atlas rule-based styling
    Andreas Neumann
    a.neumann at carto.net
    Thu Sep 14 09:39:46 PDT 2017
On the same topic:
I wonder why the Atlas rule applies on main canvas at all? Shouldn't it
only be applied in the print composer?
I always found it very, very, very odd that Atlas changes my main canvas
at all. I think it should only change map symbology in print composer.
Or is this some old design or limitation?
Andreas
On 14.09.2017 18:34, Andreas Neumann wrote:
> Hi,
> I use a rule-based styling to distinguish the feature is currently
> active in Atlas from other features that aren't active.
> This is my very simple rule:
> $id =  @atlas_featureid
> The problem is when I close the atlas data sheet (print composer) -
> then the symbology rule still remains active in the main map.
> Is there a way around this problem? Can I detect if the print composer
> atlas sheet is open or closed?
> Thanks for any ideas,
> Andreas
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
