[QGIS-Developer] pyqgis - layer.saveDefaultStyle() for PostGIS layers
Luigi Pirelli
luipir at gmail.com
Tue Sep 26 03:06:45 PDT 2017
there is a SIP specification error
https://github.com/qgis/QGIS/blob/release-2_18/python/core/qgsvectorlayer.sip#L492
should be QString &msgError /out/ );
that's the reason that error is not returned in the python side => I
suppose SIP would change C++ api in:
msg = saveStyleToDatabase( name, description, useAsDefault, uiFileContent)
Luigi Pirelli
* Boundless QGIS Support/Development: lpirelli AT boundlessgeo DOT com
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
* https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
On 25 September 2017 at 16:21, kimaidou <kimaidou at gmail.com> wrote:
> I have tried another method
> * first add default style into DB via UI -> it works
> * the use console to create a new, not default, style
> msg = ''
> layer.saveStyleToDatabase( "a new style", "some description", False, None,
> msg );
> It does not work (not new line created, and msg remains empty. No log in the
> database, which means NO query has been sent (I have change postgresql
> config to log all requests).
> But the following method works
> layer.listStylesInDatabase()
> And a new line appears in the postgresql log
> 2017-09-25 16:19:18.248 CEST [8984] mdouchin at qgis LOG: 00000: duration:
> 0.217 ms statement: SELECT id,styleName,description FROM layer_styles WHERE
> NOT (f_table_catalog='qgis' AND f_table_schema='sup' AND
> f_table_name='geo_commune' AND f_geometry_column='geom') ORDER BY
> update_time DESC
> It seems the method saveStyleToDatabase returns with no error, which can be
> caused by 2 reasons
> https://qgis.org/api/2.18/qgsvectorlayer_8cpp_source.html#l04347
> 4369 this->exportNamedStyle( qmlDocument, msgError );
> 4370 if ( !msgError.isNull() )
> 4371 {
> 4372 return;
> 4373 }
> 4374 qmlStyle = qmlDocument.toString();
> 4375
> 4376 this->exportSldStyle( sldDocument, msgError );
> 4377 if ( !msgError.isNull() )
> 4378 {
> 4379 return;
> 4380 }
> /me investigates
> 2017-09-25 15:50 GMT+02:00 Jorge Gustavo Pereira Bastos Rocha
> <jgr at di.uminho.pt>:
>> Hi,
>> It already happened to me. The first user to save a style became the owner
>> of the table. No other users were able to write on the layer_style table,
>> because there were DEFAULT PRIVILEGES defined.
>> Can you check the postgrsql log to see if there is any problem related
>> with permissions?
>> Regards,
>> Jorge Gustavo
>> ________________________________________
>> De: QGIS-Developer [qgis-developer-bounces at lists.osgeo.org] em nome de
>> kimaidou [kimaidou at gmail.com]
>> Enviado: 25 de Setembro de 2017 14:23
>> Para: Luigi Pirelli
>> Cc: qgis-developer at lists.osgeo.org
>> Assunto: Re: [QGIS-Developer] pyqgis - layer.saveDefaultStyle() for
>> PostGIS layers
>> Hi,
>> @ Tom : I really would like to trust QGIS method instead of managing
>> manually different providers.
>> @ Luigi
>> No error message, even worse : i got a message telling everything went
>> well ;)
>> (u'The style dbname=\'qgis\' host=localhost port=5432 user=\'mdouchin\'
>> sslmode=disable key=\'ogc_fid\' estimatedmetadata=true srid=2154
>> type=MultiPolygon table="sup"."geo_commune" (geom) sql= was updated in the
>> database.', True)
>> But the line is not created in the layer_styles table.
>> Michaƫl
>> 2017-09-25 14:48 GMT+02:00 Luigi Pirelli
>> <luipir at gmail.com<mailto:luipir at gmail.com>>:
>> from the code:
>> mLayer->saveStyleToDatabase and mLayer->saveDefaultStyle
>> and in
>> QString QgsMapLayer::saveDefaultStyle( bool & theResultFlag )
>> return saveNamedStyle( styleURI(), theResultFlag );
>> => seems you are doing correct.
>> any log message?
>> void QgsVectorLayerProperties::saveDefaultStyle_clicked()
>> apply();
>> QString errorMsg;
>> if ( mLayer->dataProvider()->isSaveAndLoadStyleToDBSupported() )
>> QMessageBox askToUser;
>> askToUser.setText( tr( "Save default style to: " ) );
>> askToUser.setIcon( QMessageBox::Question );
>> askToUser.addButton( tr( "Cancel" ), QMessageBox::RejectRole );
>> askToUser.addButton( tr( "Local database" ), QMessageBox::NoRole );
>> askToUser.addButton( tr( "Datasource database" ), QMessageBox::YesRole
>> switch ( askToUser.exec() )
>> case 0:
>> return;
>> case 2:
>> mLayer->saveStyleToDatabase( "", "", true, "", errorMsg );
>> if ( errorMsg.isNull() )
>> return;
>> break;
>> default:
>> break;
>> bool defaultSavedFlag = false;
>> errorMsg = mLayer->saveDefaultStyle( defaultSavedFlag );
>> if ( !defaultSavedFlag )
>> QMessageBox::warning( this, tr( "Default Style" ), errorMsg );
>> Luigi Pirelli
>> On 25 September 2017 at 13:44, Tom Chadwin
>> <tom.chadwin at nnpa.org.uk<mailto:tom.chadwin at nnpa.org.uk>> wrote:
>> > Perhaps you have to do it manually via a PostGIS query matching
>> > f_table_catalog, f_table_schema, and f_table_name, and updating styleqml
>> > and
>> > stylesld?
>> > Tom
>> > Buy Pie Spy: Adventures in British pastry 2010-11 on Amazon
>> > Sent from:
>> > http://osgeo-org.1560.x6.nabble.com/QGIS-Developer-f4099106.html
>> > _______________________________________________
>> > QGIS-Developer mailing list
>> > QGIS-Developer at lists.osgeo.org<mailto:QGIS-Developer at lists.osgeo.org>
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
