[QGIS-Developer] Problem with "no Data value" with rasters when using the Layer Styling panel?
James Shaeffer james at shaeffer.co
Thu Sep 28 14:43:55 PDT 2017
I'll stab at fixing this.
James Shaeffer
On Thu, Sep 28, 2017 at 09:55:14PM +0600, Stéphane Henriod wrote:
> Hi all
> just trying one last time to get attention on this bug :-)
> The bug is still present on the last 2.99
> As usual, I apologize for complaining while not being able to take care of
> it myself...
> Easiest way to understand what is currently wrong is this screencast:
> https://vimeo.com/219467091
> With my little understanding, I would assume that the correction of this
> bug is not a "big thing"? But maybe I am overlooking something
> Thanks!
> Stéphane
> Le mercredi 21 juin 2017, Stéphane Henriod <stephanebek at gmail.com> a écrit :
> > Hi all
> > Apparently, this has been confirmed as a bug. Is anyone willing / able to
> > take care of it?
> > Thanks a lot and cheers
> > Stéphane (who really feels sorry to raise such questions, while not being
> > able himself to actively contribute to the resolution of such bugs)
> > Le jeudi 1 juin 2017, Stéphane Henriod <stephanebek at gmail.com
> > <javascript:_e(%7B%7D,'cvml','stephanebek at gmail.com');>> a écrit :
> >> Hi again
> >> in doubt, I have opened a ticket here: https://issues.qgis.org/
> >> issues/16649
> >> Cheers
> >> Stéphane
> >> Le mardi 30 mai 2017, Stéphane Henriod <stephanebek at gmail.com> a écrit :
> >>> PS: screencast to better explain the issue: https://vimeo.com/219467091
> >>>> Hi
> >>>> I am testing the layer styling panel (shortcut F7) with the latest
> >>>> Nightly build on the Ubuntu repositories.
> >>>> By default, the NoData value is -9999. If I add "10" as additional
> >>>> NoData value, nothing happens.
> >>>> If I do the same in the layer properties, then the expected behavior
> >>>> happens: all pixels with value "10" are not rendered.
> >>>> So it seems that the manually added NoData values in the Layer Styling
> >>>> Panel are not considered.
> >>>> Can someone else replicate this problem? Should I open a ticket?
> >>>> Cheers
> >>>> Stéphane
> >>>> “When you travel, remember that a foreign country is not designed to
> >>>> make you comfortable. It is designed to make its own people comfortable."
> >>>> -- Clifton Fadiman
> >>> -- Clifton Fadiman
> >> “When you travel, remember that a foreign country is not designed to make
> >> you comfortable. It is designed to make its own people comfortable." --
> >> Clifton Fadiman
> > Clifton Fadiman
> Clifton Fadiman
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
More information about the QGIS-Developer mailing list
