[QGIS-Developer] Problem with "no Data value" with rasters when using the Layer Styling panel?
Stéphane Henriod
stephanebek at gmail.com
Thu Sep 28 08:55:14 PDT 2017
Hi all
just trying one last time to get attention on this bug :-)
The bug is still present on the last 2.99
As usual, I apologize for complaining while not being able to take care of
it myself...
Easiest way to understand what is currently wrong is this screencast:
https://vimeo.com/219467091
With my little understanding, I would assume that the correction of this
bug is not a "big thing"? But maybe I am overlooking something
Thanks!
Stéphane
Le mercredi 21 juin 2017, Stéphane Henriod <stephanebek at gmail.com> a écrit :
> Hi all
> Apparently, this has been confirmed as a bug. Is anyone willing / able to
> take care of it?
> Thanks a lot and cheers
> Stéphane (who really feels sorry to raise such questions, while not being
> able himself to actively contribute to the resolution of such bugs)
> Le jeudi 1 juin 2017, Stéphane Henriod <stephanebek at gmail.com
> <javascript:_e(%7B%7D,'cvml','stephanebek at gmail.com');>> a écrit :
>> Hi again
>> in doubt, I have opened a ticket here: https://issues.qgis.org/
>> issues/16649
>> Cheers
>> Stéphane
>> Le mardi 30 mai 2017, Stéphane Henriod <stephanebek at gmail.com> a écrit :
>>> PS: screencast to better explain the issue: https://vimeo.com/219467091
>>>> Hi
>>>> I am testing the layer styling panel (shortcut F7) with the latest
>>>> Nightly build on the Ubuntu repositories.
>>>> By default, the NoData value is -9999. If I add "10" as additional
>>>> NoData value, nothing happens.
>>>> If I do the same in the layer properties, then the expected behavior
>>>> happens: all pixels with value "10" are not rendered.
>>>> So it seems that the manually added NoData values in the Layer Styling
>>>> Panel are not considered.
>>>> Can someone else replicate this problem? Should I open a ticket?
>>>> Cheers
>>>> Stéphane
>>>> “When you travel, remember that a foreign country is not designed to
>>>> make you comfortable. It is designed to make its own people comfortable."
>>>> -- Clifton Fadiman
>>> -- Clifton Fadiman
>> “When you travel, remember that a foreign country is not designed to make
>> you comfortable. It is designed to make its own people comfortable." --
>> Clifton Fadiman
> Clifton Fadiman
Clifton Fadiman
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20170928/3e45c089/attachment-0001.html>
