[QGIS-Developer] GDAL 2.2.4 Python 3.6.4 Install error in Mac OS X El Capitan (10.11.6) and QGIS3.0 : setup.py and gdal-config errors
Noli Sicad
nsicad at gmail.com
Mon Apr 2 00:08:46 PDT 2018
Hi William,
I am trying python GDAL (GDAL2.2.4 and Python 3.6.4) in Mac OS X El
Capitan (10.11.6) and QGIS3.0.
sudo pip3 install gdal
I got this error:
File "/private/tmp/pip-build-e4ca_ecz/gdal/setup.py", line 138, in fetch_config
raise gdal_config_error(e)
__main__.gdal_config_error: [Errno 2] No such file or directory:
'gdal-config': 'gdal-config'
I tried several suggestions in the net however, the error getting
worst that this.
Any suggestion how to fix this?
Here's the log below.
Thanks.
Noli
Nolis-MBP:AA_QGIS nolisicad$ sudo pip3 install gdal
Password:
The directory '/Users/nolisicad/Library/Caches/pip/http' or its parent
directory is not owned by the current user and the cache has been
disabled. Please check the permissions and owner of that directory. If
executing pip with sudo, you may want sudo's -H flag.
The directory '/Users/nolisicad/Library/Caches/pip' or its parent
directory is not owned by the current user and caching wheels has been
disabled. check the permissions and owner of that directory. If
Collecting gdal
Downloading GDAL-2.2.4.tar.gz (475kB)
100% |████████████████████████████████| 481kB 733kB/s
Complete output from command python setup.py egg_info:
running egg_info
creating pip-egg-info/GDAL.egg-info
writing pip-egg-info/GDAL.egg-info/PKG-INFO
writing dependency_links to pip-egg-info/GDAL.egg-info/dependency_links.txt
writing top-level names to pip-egg-info/GDAL.egg-info/top_level.txt
writing manifest file 'pip-egg-info/GDAL.egg-info/SOURCES.txt'
warning: manifest_maker: standard file '-c' not found
File "/private/tmp/pip-build-e4ca_ecz/gdal/setup.py", line 134,
in fetch_config
p = subprocess.Popen([command, args], stdout=subprocess.PIPE)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/subprocess.py",
line 709, in __init__
restore_signals, start_new_session)
line 1344, in _execute_child
raise child_exception_type(errno_num, err_msg, err_filename)
FileNotFoundError: [Errno 2] No such file or directory:
'../../apps/gdal-config': '../../apps/gdal-config'
During handling of the above exception, another exception occurred:
File "/private/tmp/pip-build-e4ca_ecz/gdal/setup.py", line 182,
in get_gdal_config
return fetch_config(option, gdal_config = self.gdal_config)
in fetch_config
in fetch_config
File "<string>", line 1, in <module>
File "/private/tmp/pip-build-e4ca_ecz/gdal/setup.py", line 342,
in <module>
**extra )
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/distutils/core.py",
line 148, in setup
dist.run_commands()
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/distutils/dist.py",
line 955, in run_commands
self.run_command(cmd)
line 974, in run_command
cmd_obj.run()
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/setuptools/command/egg_info.py",
line 279, in run
self.find_sources()
line 306, in find_sources
mm.run()
line 533, in run
self.add_defaults()
line 562, in add_defaults
sdist.add_defaults(self)
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/setuptools/command/py36compat.py",
line 36, in add_defaults
self._add_defaults_ext()
line 119, in _add_defaults_ext
build_ext = self.get_finalized_command('build_ext')
File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/distutils/cmd.py",
line 299, in get_finalized_command
cmd_obj.ensure_finalized()
line 107, in ensure_finalized
self.finalize_options()
File "/private/tmp/pip-build-e4ca_ecz/gdal/setup.py", line 217,
in finalize_options
self.gdaldir = self.get_gdal_config('prefix')
File "/private/tmp/pip-build-e4ca_ecz/gdal/setup.py", line 191,
in get_gdal_config
return fetch_config(option)
in fetch_config
Command "python setup.py egg_info" failed with error code 1 in
