[QGIS-Developer] GDAL 2.2.4 Python 3.6.4 Install error in Mac OS X El Capitan (10.11.6) and QGIS3.0 : setup.py and gdal-config errors
Noli Sicad
nsicad at gmail.com
Tue Apr 3 01:41:06 PDT 2018
Disregard this error.
The processing plugin loads now properly.
I think downloaded and installed the wrong version (32bit / 10.6) of
the python3.6.x. instead of 64bit / 10.9). It seems that python 3.6.5
is properly installed now.
Noli
On Mon, Apr 2, 2018 at 5:08 PM, Noli Sicad <nsicad at gmail.com> wrote:
> Hi William,
> I am trying python GDAL (GDAL2.2.4 and Python 3.6.4) in Mac OS X El
> Capitan (10.11.6) and QGIS3.0.
> sudo pip3 install gdal
> I got this error:
> File "/private/tmp/pip-build-e4ca_ecz/gdal/setup.py", line 138, in fetch_config
> raise gdal_config_error(e)
> __main__.gdal_config_error: [Errno 2] No such file or directory:
> 'gdal-config': 'gdal-config'
> I tried several suggestions in the net however, the error getting
> worst that this.
> Any suggestion how to fix this?
> Here's the log below.
> Thanks.
> Noli
> Nolis-MBP:AA_QGIS nolisicad$ sudo pip3 install gdal
> Password:
> The directory '/Users/nolisicad/Library/Caches/pip/http' or its parent
> directory is not owned by the current user and the cache has been
> disabled. Please check the permissions and owner of that directory. If
> executing pip with sudo, you may want sudo's -H flag.
> The directory '/Users/nolisicad/Library/Caches/pip' or its parent
> directory is not owned by the current user and caching wheels has been
> disabled. check the permissions and owner of that directory. If
> Collecting gdal
> Downloading GDAL-2.2.4.tar.gz (475kB)
> 100% |████████████████████████████████| 481kB 733kB/s
> Complete output from command python setup.py egg_info:
> running egg_info
> creating pip-egg-info/GDAL.egg-info
> writing pip-egg-info/GDAL.egg-info/PKG-INFO
> writing dependency_links to pip-egg-info/GDAL.egg-info/dependency_links.txt
> writing top-level names to pip-egg-info/GDAL.egg-info/top_level.txt
> writing manifest file 'pip-egg-info/GDAL.egg-info/SOURCES.txt'
> warning: manifest_maker: standard file '-c' not found
> Traceback (most recent call last):
> File "/private/tmp/pip-build-e4ca_ecz/gdal/setup.py", line 134,
> in fetch_config
> p = subprocess.Popen([command, args], stdout=subprocess.PIPE)
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/subprocess.py",
> line 709, in __init__
> restore_signals, start_new_session)
> line 1344, in _execute_child
> raise child_exception_type(errno_num, err_msg, err_filename)
> FileNotFoundError: [Errno 2] No such file or directory:
> '../../apps/gdal-config': '../../apps/gdal-config'
> During handling of the above exception, another exception occurred:
> File "/private/tmp/pip-build-e4ca_ecz/gdal/setup.py", line 182,
> in get_gdal_config
> return fetch_config(option, gdal_config = self.gdal_config)
> in fetch_config
> in fetch_config
> File "<string>", line 1, in <module>
> File "/private/tmp/pip-build-e4ca_ecz/gdal/setup.py", line 342,
> in <module>
> **extra )
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/distutils/core.py",
> line 148, in setup
> dist.run_commands()
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/distutils/dist.py",
> line 955, in run_commands
> self.run_command(cmd)
> line 974, in run_command
> cmd_obj.run()
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/setuptools/command/egg_info.py",
> line 279, in run
> self.find_sources()
> line 306, in find_sources
> mm.run()
> line 533, in run
> self.add_defaults()
> line 562, in add_defaults
> sdist.add_defaults(self)
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/site-packages/setuptools/command/py36compat.py",
> line 36, in add_defaults
> self._add_defaults_ext()
> line 119, in _add_defaults_ext
> build_ext = self.get_finalized_command('build_ext')
> File "/Library/Frameworks/Python.framework/Versions/3.6/lib/python3.6/distutils/cmd.py",
> line 299, in get_finalized_command
> cmd_obj.ensure_finalized()
> line 107, in ensure_finalized
> self.finalize_options()
> File "/private/tmp/pip-build-e4ca_ecz/gdal/setup.py", line 217,
> in finalize_options
> self.gdaldir = self.get_gdal_config('prefix')
> File "/private/tmp/pip-build-e4ca_ecz/gdal/setup.py", line 191,
> in get_gdal_config
> return fetch_config(option)
> in fetch_config
> Command "python setup.py egg_info" failed with error code 1 in
