[QGIS-Developer] Custom widgets and Qt Designer 4 and 5
Denis Rouzaud
denis.rouzaud at gmail.com
Wed Apr 4 04:42:03 PDT 2018
Hi Etienne,
qgis_customwidgets.py is responsible of replacing the cpp header by
qgis.gui.
It should be located in /pythonX/dist-packages/PyQt5/uic/widget-plugins/
To work, this file needs bbe able to import qgis.gui. If it fails, there
will be no replacement.
Can you check if this file is present and if you can import qgis.gui?
Cheers,
Denis
Le mar. 3 avr. 2018 à 14:25, Etienne Trimaille <etienne.trimaille at gmail.com>
a écrit :
> Hi Matteo,
> I'm finally trying to use custom widgets from QT Creator instead of using
> promoted widgets.
> I'm facing the same issue with the generated path. It's not using
> "qgis.gui" so it's failing during the import in QGIS.
> Did you fix this issue?
> I can manually fix these imports, but I'm asking if there is a fix for
> that. Thanks
> 2018-03-20 14:33 GMT+01:00 matteo <matteo.ghetta at gmail.com>:
>> Hi Matthias,
>> >> * not being able to see the QGS widgets in QT Designer 5 is related
>> with
>> >> GDAL version, isn't it? If copying in the
>> >> /usr/...../pyqt5/plugin/designer the libqgiscustomwidget not compiled
>> >> against gdal >= 2.20 won't work
>> > That's what I was talking about. It doesn't matter which gdal version
>> > you link against.
>> ok so technically one I have the file libqgiscustomwidget.so and I've
>> copied it into the folder I can even clean the directory of QGIS
>> (compiled against gdal 2.20)?
>> Thanks for the patience ;)
>> Matteo
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180404/4b165252/attachment.html>
