[QGIS-Developer] Custom widgets and Qt Designer 4 and 5
matteo
matteo.ghetta at gmail.com
Thu Apr 5 07:07:10 PDT 2018
Hi Etienne,
> I'm finally trying to use custom widgets from QT Creator instead of using
> promoted widgets.
> I'm facing the same issue with the generated path. It's not using
> "qgis.gui" so it's failing during the import in QGIS.
> Did you fix this issue?
> I can manually fix these imports, but I'm asking if there is a fix for
> that. Thanks
no I did not fix it. I think that all the issue is because I'm compiling
qgis without installing it on the system (so no make install).
But that's only my idea ;)
Cheers
Matteo
