[QGIS-Developer] issues with 1:n relations
DelazJ
delazj at gmail.com
Tue Apr 17 10:45:56 PDT 2018
2018-04-17 19:25 GMT+02:00 Raymond Nijssen <r.nijssen at terglobo.nl>:
> Hi Giovanni,
> Not sure what you exactly did, I wasn't even aware of QGIS being able
> doing any 1:n relations.
> Raymond,
https://docs.qgis.org/2.18/en/docs/user_manual/working_with_vector/attribute_table.html#creating-one-or-many-to-many-relations
Regards,
Harrissou
> But a few months ago I had to do a more complex 1:n relation, including
> adding some fields. I solved it by using a virtual layer. The description
> is here:
> http://www.qgis.nl/2018/02/16/english-diagrams-for-features/?lang=en
> Maybe it could help you. Or maybe you know an easier way for doing this?
> Btw, I would normally do this using PostGIS but this was a question from a
> customer.
> Ciao,
> Raymond
> On 17-04-18 18:23, Giovanni Manghi wrote:
>> Hi all,
>> I have recently had to test some scenario with 1:n relations in QGIS and
>> I have found a few issues and would like to know if someone has them in its
>> pipeline/todo list, eventually to share the effort for the fixes.
>> Anyway I'm also interested on your feedback on the matter.
>> 1) 1:n relations in QGIS3. They seems unusable at the moment. When
>> opening a parent layer feature form, the area/space where the child records
>> should show does not show/cannot be expanded.
>> 2) 1:n relations in QGIS 2.18.
>> I have tried a scenario (that to me seems not unusual at all) where both
>> the parent and the child are layers/tables with a geometry.
>> The case where the child has its own geometries does not seems well
>> implemented (if implemented at all) in the context of the relation feature
>> form and this causes the following:
>> a) from within the parent feature form, if I edit the child and try add a
>> new record there is no tool to allow also add/digitize the proper geometry.
>> The user can still enter only the attributes and when saving I have seen
>> two things happen *) In a test project using GPKGs this led effectively to
>> a record orphaned of its geometry *) In a test project using PostGIS layers
>> the edits are *silently* discarded, no warning, no error, not even in QGIS
>> logs.
>> b) from within the parent feature form, when toggling editing for the
>> child, this is effectively put it in edit state also in the layers panel.
>> So a user can "move away" the parent feature form (that it is on first
>> plane) and use the standard editing tools to add a geometry to the child
>> layer. When finished the attributes form pop-up and can be used to fill the
>> data, with the important issue/limitation that the "referencing field" is
>> *not* automatically filled as it is done when working within the relation
>> form. Once saved the new record will also show in the relation form. This
>> seems a partial workaround because as said the referencing field is not
>> automatically filled.
>> Am I missing something?
>> thanks in advance for your feedback.
>> cheers
>> -- Giovanni --
>> QGIS-Developer mailing list
>> QGIS-Developer at lists.osgeo.org
>> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Terglobo
> Fahrenheitstraat 1
> 5223 BJ 's-Hertogenbosch
> 06 25 31 49 83
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180417/48727f43/attachment.html>
