[QGIS-Developer] Can we remove a confirmation dialog in Refactor Fields algorithm?
Germán Carrillo
carrillo.german at gmail.com
Thu Apr 26 04:38:52 PDT 2018
Hi Arnaud,
the videos I included in the first message of this thread were recorded
using QGIS master. So, probably the PR you mentioned (which was merged in
2017) didn't fully fix it, since this specific dialog is still showing up
when closing the project.
Regards,
Germán
2018-04-26 3:58 GMT-05:00 Arnaud Morvan <arnaud.morvan at camptocamp.com>:
> Hello Germán
> Note that I've already fixed some related problems with
> https://github.com/qgis/QGIS/pull/4964
> Calling deleteLater should delete the dialog on next events processing.
> Do dialog and child widgets signals should be correctly disconnected.
> Arnaud
> Le 25/04/2018 à 16:55, Germán Carrillo a écrit :
> Hi All,
> In the Refactor Fields algorithm dialog there is an "Input layer" combo
> box. Each time the user selects one layer a modal dialog (message box)
> appears, letting her select whether the fields mapping should be reset or
> not. See image: [1].
> I'd like to ask you if we can get rid of such modal dialog for these
> reasons:
> 1) In general, it's good to avoid modal dialogs as they block workflows
> and hamper interaction.
> 2) Other algorithms don't use such dialog to warn users about potential
> changes in other widgets (e.g., field combo boxes dependng on the selected
> layer).
> 3) The dialog is only *useful* if the user clicks on the combo box by
> accident and wants to avoid resetting the mapping (a very specific use
> case). However, in that case the combo box shows that a new layer is
> selected, but the mapping won't correspond to it, which is confusing.
> 4) Follow these steps:
> a. Open QGIS and load a vector layer.
> b. Open the Refactor Fields dialog and press ESC to close it.
> c. Add another vector layer to QGIS.
> d. Close the QGIS project.
> As soon as you close the project (e.g., when you want to start a new one)
> the modal dialog shows up :( (see this short video [2]).
> 5) The dialog is triggered too many times when using the "Fields Mapper"
> widget in a custom Processing model (and triggering it from a plugin) (see
> this short video [3]).
> So, the question for you is: Can we get rid of it? I've created a PR for
> that :D [4].
> Regards,
> Germán
> [1] http://downloads.tuxfamily.org/tuxgis/tmp/ai/reset_field_mapping.png
> [2] http://downloads.tuxfamily.org/tuxgis/tmp/ai/
> gif_refactor_fields_qgis.mp4
> [3] http://downloads.tuxfamily.org/tuxgis/tmp/ai/gif_
> refactor_fields_plugin.mp4
> [4] https://github.com/qgis/QGIS/pull/6857
> |\__
> (:>__)(
> Soluciones Geoinformáticas Libres
> http://geotux.tuxfamily.org/
> http://twitter.com/GeoTux2
> http://about.me/germancarrillo
> <http://gis.stackexchange.com/users/4972/germ%c3%a1n-carrillo>
> QGIS-Developer mailing listQGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
|\__
(:>__)(
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180426/781f8c27/attachment-0001.html>
