[QGIS-Developer] Suggestion for improved macOS build compatibility testing
Matthias Kuhn matthias at opengis.ch
Thu Apr 26 11:19:59 PDT 2018
Hi Tom,
Sorry to hear that. In the past we had macOS continuous integration
tests in place but had to disable them, because the package manager used
there (homebrew) was breaking dependencies unpredictably (I don't think
that's unexpected news for you if you are building on mac though ;) )
There is no "verification machine" on linux, but there is a docker
image. However I am not sure how easy it is to modify this image put
headers in different folders and make all the executables (xxx-config)
return the modified paths - while keeping the infrastructure maintainable.
Alternatively, I would very much like to get the mac builds back up and
running. I don't think we can do this again with the upstream homebrew
repo since we don't want our pull requests flagged erroneous for
external problems. The best alternative I see is, that we need a curated
list of formulae in a separate repository, which would not only help the
testing but potentially also the release process. Would you be
interested in taking a lead on this?
Best regards
Matthias
On 04/26/2018 07:58 PM, Tom Elwertowski wrote:
> Hi all,
> Both yesterday and today, the macOS build failed due to missing CMake
> INCLUDE specifications.
> MacOS puts each framework in a separate directory while Linux merges
> everything into /usr/local. Thus, Linux commits will compile when a
> new dependency is added as long as some other dependency already
> specifies /usr/local.
> Here is an idea that would help macOS build compatibility. Place each
> dependency on the verification build machine in a separate directory
> such as
> /usr/local/gdal-2.2.3/
> /usr/local/geos-3.6.1/
> This would make commits fail upfront on Linux if CMake INCLUDES needed
> by macOS were missing.
> Tom
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
Matthias Kuhn
matthias at opengis.ch <mailto:matthias at opengis.ch>
+41 (0)76 435 67 63 <tel:+41764356763>
OPENGIS.ch Logo <http://www.opengis.ch>
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180426/b69b2414/attachment-0001.html>
Type: image/png
Desc: not available
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180426/b69b2414/attachment-0001.png>
More information about the QGIS-Developer mailing list
