[QGIS-Developer] QGIS builds
Rudi von Staden
rudivs at gmail.com
Wed Aug 8 14:22:50 PDT 2018
I have the build environment set up from scratch on a new computer, and I'm
getting the same error building mdalprovider in the master branch
(C:\OSGeo4W64\bin\hdf5.dll : fatal error LNK1107: invalid or corrupt file:
cannot read at 0x2F0). Is there maybe a problem with hdf5.dll from osgeo4w?
I've tried downloading the source from
https://support.hdfgroup.org/ftp/HDF5/releases/hdf5-1.8/hdf5-1.8.11/src/
and building it, but even then I run into "CPack Error: Error when
generating package: HDF5".
Has nobody else had any issues with hdf5.dll? Are the instructions for 4.1
at https://github.com/qgis/QGIS/blob/master/INSTALL still accurate?
Kind regards,
Rudi
On Thu, 26 Jul 2018 at 10:34, Rudi von Staden <rudivs at gmail.com> wrote:
> Hi all,
> I'm trying to build qgis from source, but I'm getting a linking error in
> `mdalprovider`:
> I have successfully built qgis before, so any idea why this would be
> causing a problem now?
> As background, I'm trying to build a particular pull request to help with
> testing. The steps I took were:
> 1. git fetch origin pull/7396/head:rastercalc
> 2. git checkout rastercalc
> 3. delete directory build-qgis-test-x86_64 (in QGIS/ms-windows/osgeo4w)
> 4. run configonly.bat
> 5. run OSGeo4W-dev.bat (which executes `call
> C:\Users\rudi_000\Source\Repos\QGIS\ms-windows\osgeo4w\msvc-env.bat x86_64`)
> 6. run devenv from command prompt
> 7. open qgis.sln
> 8. build
> I have tried cleaning and rebuilding mdalprovider, but get the same
> result. It could be that just repeating the process described above would
> resolve the issue (from point 3.), but since it takes several hours to
> build (I'm building on a pretty old laptop) I thought I'd ask in case I'm
> doing something wrong in the process.
> Thanks,
> Rudi
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180808/89a5549b/attachment.html>
