[QGIS-Developer] How to create a simple processing script in QGIS 3.x, eg just a buffer
Andrew C
andrew.cutts at gmail.com
Thu Aug 9 05:57:03 PDT 2018
Hi All,
Can someone offer me some guidance on the new scripting process in QGIS 3x?
If I take the create script from template option and make some very minor
changes (below), why am I not writing a buffer? The script will execute
with no errors, is this line buffered_layer =
processing.run("native:buffer",...... even being run?
The lines I have changed from the template are show with ###
I am not clear on how QgsFeatureSinkis working, perhaps that is why I am
not getting the buffered layer? Normally in a script I could try printing
variables I cannot see where these are printed either when I tested.
Ultimately I'd like to expand the script, but first I am hoping to just be
able to call a simple buffer.
Thanks in advance for any help
Kind Regards
Andrew
* This program is free software; you can redistribute it and/or modify *
* it under the terms of the GNU General Public License as published by *
* the Free Software Foundation; either version 2 of the License, or *
* (at your option) any later version. *
from PyQt5.QtCore import QCoreApplication
from qgis.core import (QgsProcessing,
QgsFeatureSink,
QgsProcessingException,
QgsProcessingAlgorithm,
QgsProcessingParameterFeatureSource,
QgsProcessingParameterFeatureSink)
import processing
class ExampleProcessingAlgorithm(QgsProcessingAlgorithm):
This is an example algorithm that takes a vector layer and
creates a new identical one.
It is meant to be used as an example of how to create your own
algorithms and explain methods and variables used to do it. An
algorithm like this will be available in all elements, and there
is not need for additional work.
All Processing algorithms should extend the QgsProcessingAlgorithm
class.
# Constants used to refer to parameters and outputs. They will be
# used when calling the algorithm from another algorithm, or when
# calling from the QGIS console.
INPUT = 'INPUT'
OUTPUT = 'OUTPUT'
def tr(self, string):
Returns a translatable string with the self.tr() function.
return QCoreApplication.translate('Processing', string)
def createInstance(self):
return ExampleProcessingAlgorithm()
def name(self):
Returns the algorithm name, used for identifying the algorithm. This
string should be fixed for the algorithm, and must not be localised.
The name should be unique within each provider. Names should contain
lowercase alphanumeric characters only and no spaces or other
formatting characters.
return 'myscript'
def displayName(self):
Returns the translated algorithm name, which should be used for any
user-visible display of the algorithm name.
return self.tr('My Script')
def group(self):
Returns the name of the group this algorithm belongs to. This string
should be localised.
return self.tr('Example scripts')
def groupId(self):
Returns the unique ID of the group this algorithm belongs to. This
The group id should be unique within each provider. Group id should
contain lowercase alphanumeric characters only and no spaces or
other
return 'examplescripts'
def shortHelpString(self):
Returns a localised short helper string for the algorithm. This
string
should provide a basic description about what the algorithm does
and the
parameters and outputs associated with it..
return self.tr("Example algorithm short description")
def initAlgorithm(self, config=None):
Here we define the inputs and output of the algorithm, along
with some other properties.
# We add the input vector features source. It can have any kind of
# geometry.
self.addParameter(
QgsProcessingParameterFeatureSource(
self.INPUT,
self.tr('Input layer'),
[QgsProcessing.TypeVectorAnyGeometry]
# We add a feature sink in which to store our processed features
(this
# usually takes the form of a newly created vector layer when the
# algorithm is run in QGIS).
self.addParameter(
QgsProcessingParameterFeatureSink(
self.OUTPUT,
self.tr('Output layer')
def processAlgorithm(self, parameters, context, feedback):
Here is where the processing itself takes place.
# Retrieve the feature source and sink. The 'dest_id' variable is
used
# to uniquely identify the feature sink, and must be included in the
# dictionary returned by the processAlgorithm function.
source = self.parameterAsSource(
parameters,
self.INPUT,
context
# If source was not found, throw an exception to indicate that the
algorithm
# encountered a fatal error. The exception text can be any string,
but in this
# case we use the pre-built invalidSourceError method to return a
standard
# helper text for when a source cannot be evaluated
if source is None:
raise
QgsProcessingException(self.invalidSourceError(parameters, self.INPUT))
(sink, dest_id) = self.parameterAsSink(
parameters,
self.OUTPUT,
context,
source.fields(),
source.wkbType(),
source.sourceCrs()
# If sink was not created, throw an exception to indicate that the
algorithm
but in this
# case we use the pre-built invalidSinkError method to return a
standard
# helper text for when a sink cannot be evaluated
if sink is None:
raise QgsProcessingException(self.invalidSinkError(parameters,
self.OUTPUT))
# Compute the number of steps to display within the progress bar and
# get features from source
total = 100.0 / source.featureCount() if source.featureCount() else
0
features = source.getFeatures()
for current, feature in enumerate(features):
# Stop the algorithm if cancel button has been clicked
if feedback.isCanceled():
break
# Add a feature in the sink
sink.addFeature(feature, QgsFeatureSink.FastInsert)
# Update the progress bar
feedback.setProgress(int(current * total))
# To run another Processing algorithm as part of this algorithm,
you can use
# processing.run(...). Make sure you pass the current context and
feedback
# to processing.run to ensure that all temporary layer outputs are
available
# to the executed algorithm, and that the executed algorithm can
send feedback
# reports to the user (and correctly handle cancelation and
progress reports!)
### removed if False:
buffered_layer = processing.run("native:buffer", { ### removed PARAM
'INPUT': dest_id,
'DISTANCE': 1.5,
'SEGMENTS': 5,
'END_CAP_STYLE': 0,
'JOIN_STYLE': 0,
'MITER_LIMIT': 2,
'DISSOLVE': False,
'OUTPUT': 'memory:'
}, context=context, feedback=feedback)['OUTPUT']
# Return the results of the algorithm. In this case our only result
is
# the feature sink which contains the processed features, but some
# algorithms may return multiple feature sinks, calculated numeric
# statistics, etc. These should all be included in the returned
# dictionary, with keys matching the feature corresponding parameter
# or output names.
return {self.OUTPUT: buffered_layer} ### changed output name
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180809/7b26eb12/attachment-0001.html>
