[QGIS-Developer] OpenCL and macOS
Tom Elwertowski
telwertowski at comcast.net
Thu Aug 9 08:05:01 PDT 2018
The directory found by CMake
(/System/Library/Frameworks/OpenCL.framework/Headers/) contains only .h
files.
The khronos site mentioned by Denis offers cl.hpp for v1 and cl2.hpp for
v2. qgsopenclutils.h includes cl2.hpp.
Should I download and try cl.hpp on my mac? If it compiles, how can I
test running it.
Tom
On 8/9/18 10:12 AM, Denis Rouzaud wrote:
> I think the issue is that there is no header installed on mac
> https://stackoverflow.com/a/23079478/1548052
> Le jeu. 9 août 2018 à 16:06, Alessandro Pasotti <apasotti at gmail.com
> <mailto:apasotti at gmail.com>> a écrit :
> On Thu, Aug 9, 2018 at 3:54 PM, Tom Elwertowski
> <telwertowski at comcast.net <mailto:telwertowski at comcast.net>> wrote:
> Hi all,
> A recent change added OpenCL. Compilation fails on macOS because
> Apple provides v1.2 (macOS 10.13) while QGIS seems to require v2.
> That's wierd: 1.1 is what should be required can you file a ticket
> and provide full logs?
> Adding a version to FIND_PACKAGE will fix the macOS compile and
> not use OpenCL.
> Apple has deprecated OpenCL in favor of its own Metal
> technology. OpenCL will remain for macOS 10.14 (Mojave, fall
> 2018) but may be removed after fall 2019.
> For the future, either OpenCL must remain an optional QGIS
> feature in order to support macOS or the API needs to be
> abstracted so that macOS can use Metal while other OSs use OpenCL.
> OpenCL is an optional feature and there is no plan to change that.
> Tom
> LinkedIn: https://www.linkedin.com/in/thomas-elwertowski-a0886032
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> <mailto:QGIS-Developer at lists.osgeo.org>
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Alessandro Pasotti
> w3: www.itopen.it <http://www.itopen.it>
> QGIS-Developer at lists.osgeo.org <mailto:QGIS-Developer at lists.osgeo.org>
> Denis Rouzaud
> denis at opengis.ch <mailto:denis at opengis.ch>
> +41 76 370 21 22
