[QGIS-Developer] K-neighbour concave hull algorithm
Luigi Pirelli
luipir at gmail.com
Thu Aug 16 01:12:51 PDT 2018
I agree with the progressive approach in your PR e.g. just integrate the
alg as processing algorithm. A 2) approach can come later
https://github.com/qgis/QGIS/pull/7626
tnks to point out about this alg/plugin, I didn't realized it's
existence... it's a pain we missed the opportunity to work on it, just when
we where in FOSS4G-EU that was hosted by the university/department that
published the algorithm.
Luigi Pirelli
* LinkedIn: https://www.linkedin.com/in/luigipirelli
* Stackexchange: http://gis.stackexchange.com/users/19667/luigi-pirelli
* GitHub: https://github.com/luipir
* Mastering QGIS 2nd Edition:
https://www.packtpub.com/big-data-and-business-intelligence/mastering-qgis-second-edition
* Hire me: http://goo.gl/BYRQKg
On Wed, 15 Aug 2018 at 12:47, Rudi von Staden <rudivs at gmail.com> wrote:
> Hi all,
> I've been using the concave hull processing algorithm as part of a model
> which iterates over species distribution data to create a basic
> distribution polygon. I've found that it can produce very unexpected
> outputs for certain input data, so I don't think it's a good algorithm to
> use 'unsupervised'.
> The results from the k-neighbour concave hull algorithm (
> https://www.researchgate.net/publication/220868874_Concave_hull_A_k-nearest_neighbours_approach_for_the_computation_of_the_region_occupied_by_a_set_of_points)
> are generally more pleasing and will never have strange pinches or ignored
> points (although it also doesn't provide for holes). From my testing I
> think the outputs correspond more to how someone would naturally
> circumscribe a set of points. As such I would argue for it to be included
> as one of the default algorithms.
> There is an existing plugin (
> https://github.com/detlevn/QGIS-ConcaveHull-Plugin) which is pretty
> decent but it hasn't been updated to work with QGIS3. I've also come across
> a C++ implementation (
> https://www.codeproject.com/Articles/1201438/The-Concave-Hull-of-a-Set-of-Points)
> which seems to have a lot of optimisation advantages.
> I see three options:
> 1. Update the plugin code and streamline it as a qgis algorithm. I'd be
> happy to give this a go if there's support and I think it would be
> relatively straightforward.
> 2. Adapt the c++ implementation and add it as a native algorithm. This
> would probably have significant performance advantages, but may not be
> worth the effort. I'm not that confident with C++ and would at least need a
> fair amount of guidance if someone else doesn't want to take it on. I did
> reach out to the developer and he'd be happy for his code to be used if it
> comes to that.
> 3. Update the plugin for QGIS3 (or at least the parts of it that I need).
> I would do this anyway if we don't proceed with either of the other options.
> Any thoughts?
> Rudi
> QGIS-Developer mailing list
> QGIS-Developer at lists.osgeo.org
> List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
> Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180816/a7f187ea/attachment.html>
