[QGIS-Developer] [Qgis-developer] OTB and LiDAR tools as separate plugins
Martin Isenburg
martin.isenburg at gmail.com
Thu Aug 23 02:18:38 PDT 2018
Hello from Zanzibar,
In the next three days I'd like to tackle recreating the LAStools toolbox
the way it was available in QGIS 2.4 through 2.18 to also in QGIS 3.2. Is
there a guide / example that I can follow to provide the LiDAR tools
provider as a separate plugin as we've discussed it previously? Has anyone
else created such a processing plugin that is residing outside of QGIS who
is / will come to Tanzania?
Regards.
Martin
On Thu, Aug 23, 2018 at 11:13 AM, Martin Isenburg <martin.isenburg at gmail.com
> Regards.
> Martin
> On Thu, Feb 2, 2017 at 8:36 AM, Victor Olaya <volayaf at gmail.com> wrote:
>> Martin
>> That might be my fault. I mentioned that, by having the LiDAR tools
>> provider as a separate plugin, that allows to ship the tools with it
>> (not with QGIS, but with the plugin itself, which you will manage and
>> release whenever you want). Of course, you can still provide the
>> downloads from your site as usual, this would just be a more practical
>> solution, to avoid having to setup the LASTools path in Processing
>> Cheers
>> 2017-02-02 2:04 GMT+01:00 Martin Isenburg <martin.isenburg at gmail.com>:
>> > Hello,
>> >> One thing to keep in mind is that not all the LIDAR tools are open
>> >> sources, 2/3 of the LAStools aren't and slightly distort the output
>> after
>> >> certain point limits are exceeded. My opinion is that QGIS shouldn't
>> ship or
>> >> assist the distribution of closed binaries.
>> > Not sure who suggested the notion that LAStools binaries will be shipped
>> > with QGIS or that there maybe will be an auto-download of sorts ...
>> there
>> > will not. The LAStools package can be used as a toolbox in ArcGIS,
>> IMAGINE,
>> > FME, and QGIS or as a stand alone software. I see more and more LiDAR
>> > practitioners (those that I am teaching) doing their GIS with the Q
>> instead
>> > of Argh and the QGIS toolboxes the most up-to-date toolboxes. If a user
>> > wants to use LAStools (whether via QGIS or not) the tools will only be
>> > available via my site and not be bundled.
>> > Regards from the Philippines,
>> > Martin
>> > _______________________________________________
>> > Qgis-developer mailing list
>> > Qgis-developer at lists.osgeo.org
>> > List info: https://lists.osgeo.org/mailman/listinfo/qgis-developer
>> > Unsubscribe: https://lists.osgeo.org/mailman/listinfo/qgis-developer
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180823/6f9e4075/attachment-0001.html>
