[QGIS-Developer] [Qgis-developer] OTB and LiDAR tools as separate plugins
Alexander Bruy
alexander.bruy at gmail.com
Thu Aug 23 02:42:57 PDT 2018
Hi Martin,
there are a lot of Processing providers which are not part of the QGIS
core. You can easily find
some of them in the QGIS Plugin repository by "Processing" keyword.
Also in QGIS sources
there is an example provider which can be used as staring point, see
https://github.com/qgis/QGIS/tree/master/python/plugins/processing/algs/exampleprovider.
чт, 23 серп. 2018 о 12:19 Martin Isenburg <martin.isenburg at gmail.com> пише:
> Hello from Zanzibar,
> In the next three days I'd like to tackle recreating the LAStools toolbox the way it was available in QGIS 2.4 through 2.18 to also in QGIS 3.2. Is there a guide / example that I can follow to provide the LiDAR tools provider as a separate plugin as we've discussed it previously? Has anyone else created such a processing plugin that is residing outside of QGIS who is / will come to Tanzania?
> Regards.
> Martin
Alexander Bruy
