[QGIS-Developer] [PyQt] Multiple inheritance from custom widgets and uic
Denis Rouzaud
denis.rouzaud at gmail.com
Thu Aug 30 03:51:44 PDT 2018
Hi Alexander,
(forwarding to qgis-dev list, as I think it should be also referenced there)
Here is the reply I got from Phil:
> I can confirm it is a bug, however the fix is non-trivial so it won't get
fixed quickly. The fundamental problem is that the code has the assumption
that all custom widgets will reside in the PyQt5 package hard-coded (but
even then it's not quite as simple as that).
He also wrote it's on his todo list in the next 3-4 weeks on that time, but
I don't think it has been solved.
Best wishes,
Denis
Le jeu. 30 août 2018 à 08:35, Alexander Bruy <alexander.bruy at gmail.com> a
écrit :
> Hi all,
> usually I use following code to create a form from the Qt Designer's .ui
> file dynamically
> from PyQt5 import uic
> FORM_CLASS, BASE_CLASS = uic.loadUiType('/path/to/ui/file.ui')
> class MyDialog(BASE_CLASS, FORM_CLASS):
> def __init__(self, parent=None):
> super(MyDialog, self).__init__(parent)
> self.setupUi(self)
> and everything works fine.
> But seems this approach seems does not work with multiple inheritance.
> There is a custom dialog class (QDialog subclass with custom UI and some
> logic) available in the API library. I want to subclass this custom dialog
> and also apply my own UI to it. I tried following code
> from api.ui import CustomDialogBase
> class MyDialog(BASE_CLASS, CustomDialogBase, FORM_CLASS):
> self.setupUi(self)
> But this raises type error
> TypeError: Cannot create a consistent method resolution order (MRO)
> for bases QDialog, QgsOptionsDialogBase, Ui_OptionsDialog
> As I understand, this is because all classes have the same base class
> QDialog.
> Also I tried to specify only one parent class — custom dialog, as it is
> already subclassed from QDialog
> class MyDialog(CustomDialogBase, FORM_CLASS):
> self.setupUi(self)
> But this also does not work, with the error
> AttributeError: 'MyDialog' object has no attribute 'groupBox'
> As I understand, in this case issue is that FORM_CLASS is a QDialog
> subclass,
> not CustomDialogBase's subclass. After some searching I have found this
> thread
> https://riverbankcomputing.com/pipermail/pyqt/2017-October/039647.html.
> Am I right that currently the only way to solve my issue is to construct
> form from the compiled .ui file?
> Thanks
> Alexander Bruy
> PyQt mailing list PyQt at riverbankcomputing.com
> https://www.riverbankcomputing.com/mailman/listinfo/pyqt
Denis Rouzaud
denis at opengis.ch <denis at opengis.ch>
+41 76 370 21 22
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180830/a21c1e98/attachment.html>
