[QGIS-Developer] Popup window within Processing crashes QGIS
C Hamilton
adenaculture at gmail.com
Fri Aug 31 05:24:11 PDT 2018
Thanks Nyall!!! Unfortunately I was trying to make this a processing
routine when I shouldn't have. It is good to know the boundaries. This
function really requires user interactivity.
Calvin
On Thu, Aug 30, 2018 at 9:27 PM, Nyall Dawson <nyall.dawson at gmail.com>
wrote:
> On Thu, 30 Aug 2018 at 23:38, C Hamilton <adenaculture at gmail.com> wrote:
> > I have an algorithm that during execution gathers information from the
> data and then pops up a window for the user to select what the user would
> like to do.
> > Is this possible in the Processing framework? I have tried doing this in
> processAlgorithm and it crashes QGIS. Here is how I call the popup window.
> No - this is not supported and goes against the very fundamental
> design of Processing. Argggh! ;)
> But seriously, Processing was designed with the intention that all
> user choices are made up-front. This allows algorithms to be nicely
> executed inside of models, without the model halting mid-way waiting
> for user input. It also allows algorithms, scripts, models, etc to be
> run from headless environments such as console scripts.
> In this case, you're getting a crash because you're trying to create
> GUI components from your algorithm which is being executed in a
> background thread. This is a big no-no in Qt land, and usually results
> in a crash.
> Nyall
> > fieldsDialog = SelectionDialog(self.tableFeatures)
> > fieldsDialog.exec_()
> > items = fieldsDialog.selected
> > Here is the beginning of the SelectionDialong class.
> > class SelectionDialog(QDialog, FIELDS_CLASS):
> > def __init__(self, feat, parent=None):
> > super(SelectionDialog, self).__init__(parent)
> > self.setupUi(self)
> > Prior to Processing I passed in iface.mainWindow() as the parent. Is
> there a proper parent in Processing to pass? Perhaps this is the reason it
> is crashing.
> > def __init__(self, iface, feat):
> > super(SelectionDialog, self).__init__(iface.mainWindow())
> > self.setupUi(self)
> > Thanks,
> > Calvin
URL: <http://lists.osgeo.org/pipermail/qgis-developer/attachments/20180831/f2686b84/attachment.html>
